LMH2121 具有 40dB 动态范围的 3 GHz 快速响应线性功率检测器
数据:
产品信息
描述 The LMH2121 is an accurate fast-responding power detector / RF envelope detector. Its response between an RF input signal and DC output signal is linear. The typical response time of 165 ns makes the device suitable for an accurate power setting in handsets during a rise time of RF transmission slots. It can be used in all popular communications standards: 2G/3G/4G/WAP. The LMH2121 has an input range from −28 dBm to +12 dBm. Over this input range the device has an intrinsic high insensitivity for temperature, supply voltage and loading. The bandwidth of the device is from 100 MHz to 3 GHz, covering 2G/3G/4G/WiFi wireless bands.As a result of the unique internal architecture, the device shows an extremely low part-to-part variation of the detection curve. This is demonstrated by its low intercept and slope variation as well as a very good linear conformance. Consequently the required characterization and calibration efforts are low.The device is active for EN = High; otherwise it is in a low power consumption shutdown mode. To save power and allow for two detector outputs in parallel, the output (OUT) is high impedance during shutdown.The LMH2121 is offered in a tiny 4-bump DSBGA package: 0.866 mm x 1.07 mm x 0.6 mm.特性Linear Response 40 dB Power Detection Range Very Low Supply Current of 3.4 mA Short Response Time of 165 ns Stable Conversion Gain of 3.6 V/VRMS Multi-Band Operation from 100 MHz to 3 GHz Very Low Conformance Error High Temperature Stability of ±0.5 dB Shutdown Functionality Supply Range from 2.6V to 3.3V Package:4-Bump DSBGA, 0.4mm PitchAll trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(2)
元器件购买 LMH2121 相关库存
相关阅读
