LMC6482-MIL CMOS双路轨至轨输入和输出运算放大器
数据:
产品信息
描述The LMC6482-MIL device provides a common-mode range that extends to both supply rails.This rail-to-rail performance combined with excellent accuracy, due to a high CMRR, makes it uniqueamong rail-to-rail input amplifiers. The device is ideal for systems,such as data acquisition, that require a large input signal range. The LMC6482-MIL is also anexcellent upgrade for circuits using limited common-mode range amplifiers such as the TLC272 andTLC277.Maximum dynamic signal range is assured in low voltage and single supply systems by therail-to-rail output swing of the LMC6482-MIL. The rail-to-rail output swing is ensured for loadsdown to 600 Ω of the device. Ensured low-voltage characteristics and low-power dissipation make theLMC6482-MIL especially well-suited for battery-operated systems. LMC6482-MIL is also available in aVSSOP package, which is almost half the size of a SOIC-8 device. See the LMC6484 data sheet for aquad CMOS operational amplifier with these same features.特性Typical Unless Otherwise NotedRail-to-Rail Input Common-Mode Voltage Range (Ensured Over Temperature) Rail-to-Rail Output Swing (Within 20-mV of Supply Rail, 100-kΩ Load) Ensured 3-V, 5-V, and 15-V Performance Excellent CMRR and PSRR: 82 dB Ultralow Input Current: 20 fA High Voltage Gain (R L = 500 k Ω): 130 dB Specified for 2-kΩ and 600-Ω Loads Power-Good Output Available in VSSOP PackageAll trademarks are the property of their respective owners.
技术文档
数据手册(1) 相关资料(3)
元器件购买 LMC6482-MIL 相关库存
相关阅读
