产品信息
描述 The LM124/124A consists of four independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.Application areas include transducer amplifiers, DC gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM124/124A can be directly operated off of the standard +5Vdc power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional +15Vdc power supplies.特性Available with Radiation SpecificationHigh Dose Rate 100 krad(Si) ELDRS Free 100 krad(Si)Internally Frequency Compensated for Unity Gain Large DC Voltage Gain 100 dB Wide Bandwidth (Unity Gain) 1 MHz (Temperature Compensated) Wide Power Supply Range: Single Supply 3V to 32V Or Dual Supplies ±1.5V to ±16VVery Low Supply Current Drain (700 μA) — Essentially Independent of Supply Voltage Low Input Biasing Current 45 nA (Temperature Compensated) Low Input Offset Voltage 2 mV and Offset Current: 5 nA Input Common-Mode Voltage Range Includes Ground Differential Input Voltage Range Equal to the Power Supply Voltage Large Output Voltage Swing 0V to V+ − 1.5V All trademarks are the property of their respective owners.
电路图、引脚图和封装图
