产品信息
描述 This dual buffer and driver is designed for 1.65-V to 5.5-V VCC operation. The output of the SN74LVC2G07 device is open drain and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions. The maximum sink current is 32 mA.NanoFree package technology is a major breakthrough in IC packaging concepts, using the die as the package.This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.特性Dual Open-Drain Buffer Configuration -24-mA Output Drive at 3.3 V Support Translation-Up and Down Available in the Texas Instruments NanoFree™ Package Supports 5-V VCC Operation Inputs and Open-Drain Outputs Accept Voltages Up to 5.5 V Max tpd of 3.7 ns at 3.3 V Low Power Consumption, 10-µA Max ICC Typical VOLP (Output Ground Bounce) <0.8 V at VCC = 3.3 V, TA = 25°C Typical VOHV (Output VOH Undershoot) >2 V at VCC = 3.3 V, TA = 25°C Ioff Supports Live Insertion, Partial-Power-Down Mode, and Back-Drive Protection Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II ESD Protection Exceeds JESD 22 2000-V Human-Body Model (A114-A) 200-V Machine Model (A115-A) 1000-V Charged-Device Model (C101)
电路图、引脚图和封装图
