产品信息
描述The UCD90910 is a ten-rail I2C / PMBus addressable power-supply sequencer and system-health monitor. The device integrates a 12-bit ADC for monitoring up to 13 power-supply voltage, current, or temperature inputs.Twenty-six GPIO pins can be used for power-supply enables, power-on-reset signals, external interrupts, cascading, or other system functions. Twelve of these pins offer PWM functionality. Using these pins, the UCD90910 offers support for fan control, margining, and general-purpose PWM functions.Fan-control signals can be sent using PMBus commands or generated from one of two built-in fan-control algorithms. PWM outputs combined with temperature and fan-speed measurements provide a complete fan-control solution for up to ten independent fans. The TI Fusion Digital Power designer software is provided for device configuration. This PC-based graphical user interface (GUI) offers an intuitive interface for configuring, storing, and monitoring all system operating parameters.特性Monitor and Sequence Ten Voltage RailsAll Rails Sampled Every 400 µs 12-Bit ADC With 2.5-V, 0.5% Internal VREF Sequence Based on Time, Rail and Pin Dependencies Four Programmable Undervoltage and Overvoltage Thresholds per MonitorFan Control and MonitoringSupports Ten Fans With Five User-Defined Speed-vs-Temperature SetpointsSupports Two-, Three-, and Four-Wire FansNonvolatile Error and Peak-Value Logging per Monitor (up to 12 Faults) Closed-Loop Margining for Ten Rails Margin Output Adjusts Rail Voltage to Match User-Defined Margin Thresholds Programmable Watchdog Timer and System Reset Flexible Digital I/O Configuration Multiphase PWM Clock GeneratorClock Frequencies From 15.259 kHz to 125 MHzCapability to Configure Independent Clock Outputs for Synchronizing Switch-Mode Power Supplies Internal Temperature SensorJTAG and I2C / SMBus / PMBus InterfacesFullConfiguration Update while in Normal Mode CapabilityAPPLICATIONSIndustrial / ATETelecommunications and Networking EquipmentServers and Storage Systems Any System Requiring Sequencing and Monitoring of Multiple Power Rails
电路图、引脚图和封装图
