TLC2543-Q1 具有串行控制和 11 个模拟输入的汽车类 12 位模数转换器
数据:
产品信息
描述The TLC2543 is a 12-bit, switched-capacitor, successive-approximation, analog-to-digital converters. Each device, with three control inputs [chip select (CS), the input-output clock, and the address input (DATA INPUT)], is designed for communication with the serial port of a host processor or peripheral through a serial 3-state output. The device allows high-speed data transfers from the host. In addition to the high-speed converter and versatile control capability, the device has an on-chip 14-channel multiplexer that can select any one of 11 inputs or any one of three internal self-test voltages. The sample-and-hold function is automatic. At the end of conversion, the end-of-conversion (EOC) output goes high to indicate that conversion is complete. The converter incorporated in the device features differential high-impedance reference inputs that facilitate ratiometric conversion, scaling, and isolation of analog circuitry from logic and supply noise. A switched-capacitor design allows low-error conversion over the full operating temperature range.特性Qualified for Automotive Applications 12-Bit-Resolution A/D Converter 10-µs Conversion Time Over Operating Temperature 11 Analog Input Channels Three Built-In Self-Test Modes Inherent Sample-and-Hold Function Linearity Error . . . ±1 LSB Max On-Chip System Clock End-of-Conversion Output Unipolar or Bipolar Output Operation (Signed Binary With Respect to 1/2 the Applied Voltage Reference) Programmable MSB or LSB First Programmable Power Down Programmable Output Data Length CMOS Technology Application Report AvailableMicrocontroller Based Data Acquisition Using the TLC2543 12-bit Serial-Out ADC (SLAA012)
技术文档
数据手册(1)
元器件购买 TLC2543-Q1 相关库存
