TLC1541 10 位 32kSPS ADC 串行输出微处理器外设/独立、11 通道
数据:
产品信息
描述 The TLC1541 is a CMOS A/D converter built around a 10-bit switched-capacitor successive-approximation A/D converter. The device is designed for serial interface to a microprocessor or peripheral using a 3-state output with up to four control inputs [including independent SYSTEM CLOCK, I/O CLOCK, chip select (CS\), and ADDRESS INPUT]. A 2.1-MHz system clock for the TLC1541, with a design that includes simultaneous read/write operation, allows high-speed data transfers and sample rates up to 32 258 samples per second. In addition to the high-speed converter and versatile control logic, there is an on-chip, 12-channel analog multiplexer that can be used to sample any one of 11 inputs or an internal self-test voltage and a sample-and-hold function that operates automatically. The converters incorporated in the TLC1541 feature differential high-impedance reference inputs that facilitate ratiometric conversion, scaling, and analog circuitry isolation from logic and supply noises. A totally switched-capacitor design allows low-error conversion in 21 us over the full operating temperature range. The TLC1541 is available in DW, FN, and N packages. The C-suffix versions are characterized for operation from 0°C to 70°C.特性 10-Bit Resolution A/D Converter Microprocessor Peripheral or Standalone Operation On-Chip 12-Channel Analog Multiplexer Built-In Self-Test Mode Software-Controllable Sample-and-Hold Function Total Unadjusted Error . . . ±1 LSB Max Pinout and Control Signals Compatible With TLC540 and TLC549 Families of 8-Bit A/D Converters CMOS Technology
技术文档
数据手册(1)
元器件购买 TLC1541 相关库存
相关阅读
