AD5426 具有串行接口的8位高带宽乘法DAC
数据:
产品信息
优势和特点
+2.5 V to +5.5 V Supply Operation
50 MHz Serial Interface
10 MHz Multiplying Bandwidth
2.5 MSPS update rate
±10 V reference input
Low glitch energy < 2 nV-s
Pin Compatible 8- (AD5426), 10- (AD5432) Current Output DACs
Pin Compatible 12-Bit (AD5443) Current Output DACs
Guaranteed Monotonic
Four Quadrant Multiplication
Power On reset with brownout detection
Daisy Chain Mode
Readback Function
0.4 μA typical power consumption
产品详情
The AD5426/AD5432/AD5443 are CMOS 8-, 10-, and 12-bit current output digital-to-analog converters (DACs), respectively. These devices operate from a 2.5 V to 5.5 V power supply, making them suitable for battery-powered applications and many other applications.
These DACs use a double buffered, 3-wire serial interface that is compatible with SPI, QSPI™, MICROWIRE™, and most DSP interface standards. In addition, a serial data out pin (SDO) allows for daisy-chaining when multiple packages are used. Data readback allows the user to read the contents of the DAC register via the SDO pin. On power-up, the internal shift register and latches are filled with 0s and the DAC outputs are at zero scale.
As a result of manufacturing on a CMOS submicron process, the parts offer excellent 4-quadrant multiplication characteristics with large signal multiplying bandwidths of 10 MHz. The applied external reference input voltage, VREF, determines the full-scale output current. An integrated feedback resistor, RFB, provides temperature tracking and full-scale voltage output when combined with an external current to voltage precision amplifier.
The AD5426/AD5432/AD5443 DACs are available in small, 10-lead MSOP packages.
The EVAL-AD5443SDZ/EVAL-AD5446SDZ/EVAL-AD5453SDZ evaluation board is available for evaluating DAC performance. For more information, see the UG-327 evaluation board user guide.
Applications
Portable battery-powered applications
Waveform generators
Instrumentation
Programmable amplifiers and attenuators
Digitally controlled calibration
Programmable filters and oscillators
Composite video
Ultrasound
Gain, offset, and voltage trimming
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(2)
元器件购买 AD5426 相关库存
相关阅读
