--- 产品参数 ---
- 最大量程 20T
- 精度 C3
--- 产品详情 ---
额定载荷Rated load | 0~0.3…20t | 精度等级Accuracy grade | C3 |
额定输出Rated outputt | 2.0±0.2%mV/V | 蠕变Creep deformation | ≤±0.03%F.S |
滞后误差Lag error | ±0.03%F.S | 线性误差Linear error | ±0.03%F.S |
零点输出Zero outputt | ≤±1%R.C | 重复性误差Repeatability error | ≤±0.01%R.C |
输入阻抗Input impedance | 385±35Ω | 输出阻抗outputt impedance | 350±3Ω |
绝缘电阻Insulation resistance | ≥2000MΩ | 破坏载荷Charge of surety | 150% |
输出温度影响outputt temperature effect | ±0.03%F.S/10℃ | 工作温度Temperature | (-20~70)℃ |
零点温度影响Zero temperature effect | ±0.02%F.S/10℃ | 材质Texture | 合金钢或不锈钢 |
力值变送器Force value transmitter | 4~20mA、0~10V | 额定电压Rated voltage | 5~15V DC |
为你推荐
JFG-BT08 盘式扭矩传感器2024-06-19 09:57
产品型号:JFG-BT08 型号:JFG-BT08 -
JFG-BT07 微扭矩传感器2024-06-19 09:55
产品型号:JFG-BT07 型号:JFG-BT07 -
JFG-BT02 动态扭矩传感器2024-06-19 09:50
产品型号:JFG-BT02 型号:JFG-BT02 -
JFG-BT01 动态扭矩传感器2024-06-19 09:46
产品型号:JFG-BT01 型号:JFG-BT01 -
JFG-AS03 法兰扭矩传感器2024-06-19 09:33
产品型号:JFG-AS03 型号:JFG-AS03 -
JFG-AS02 微量程扭矩传感2024-06-19 09:29
产品型号:JFG-AS02 型号:JFG-AS02 -
JFG-AS01 静态扭矩传感器2024-06-19 09:23
产品型号:JFG-AS01 型号:JFG-AS01 -
三滑轮张力传感器2024-06-18 10:24
产品型号:JFG-KT02 量程:100T 精度:C3 -
张力传感器2024-06-18 10:19
产品型号:JFG-KT01 量程:20T 精度:C3 -
轮辐称重模块2024-06-18 10:11
产品型号:JFG-HW06 量程:15T 精度:C3
