企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
华易测电子
深圳市华易测电子有限公司专注仪器仪表,品类:频谱分析仪,示波器,网络分析仪,信号发生器,蓝牙测试,WLAN测试等通信设备。
283 内容数 2.9w 浏览量 3 粉丝
安捷伦3G数字信号源E4432B和E4436B
型号: E4432B和E4436B
品牌: Acrel(安科瑞)
--- 产品参数 ---
  • 品牌 安捷伦Agilent
  • 型号 E4432B
  • 型号 E4436B
  • 性能 计量合格
  • 品相 9成新
  • 品名 3G数字信号发生器
  • 净重 10kg
--- 产品详情 ---
安捷伦3G数字信号源E4432B和E4436B 安捷伦3G数字信号源E4432B和E4436B
安捷伦ESG-D系列E4430B,E4431B,E4432B,E4433B信号发生器:
E4430B频率范围: 250KHz-1GHz
E4431B频率范围: 250KHz-2GHz
E4432B频率范围: 250KHz-3GHz
E4433B频率范围: 250KHz-4GHz
安捷伦ESG-DP系列E4434B,E4435B,E4436,E4437B信号发生器:
E4434B频率范围:  250KHz-1GHz
E4435B频率范围:  250KHz-2GHz
E4436B频率范围:  250KHz-3GHz
E4437B频率范围:  250KHz-4GHz
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B仪器选件说明:
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CM 机架安装配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CN面板把手配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1CP带有把手的机架安装配件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1E5附加高wending度时基
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:1EM将所有面板连接器移到后面板上
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UNA, UN8的另一个时隙功率电平控制选件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UNB,带有机械衰减器的高功率选件
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UND,内部双ren意波形发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN5,用于UND的单信道和多信道CDMA测量专用卡。
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H03,单信道CDMA测量用卡
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN7,内部误码率分析仪
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:符合TDMA标zhun的实时I/Q基带发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:UN9,用于UN8的附加7 Mbits RAM存储器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:用于UND的W-CDMA测量zhuan用卡
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H98,W-CDMA接shou机测试基带发生器
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B选件:H99,W-CDMA、CDMA、TETRA的经改j的邻近信道功率(ACP)性能。
 主要技术指标:
1,250 kHz 至 1Ghz,2Ghz,3Ghz,4, GHz 频率范围,
2,RF 调制带宽达 35 MHz
3,可选的双ren意波形发生器,
4,和/或实时 I/Q 基带发生器
5,40 MHz 采样率和 14-bit I/Q 分辨率,
6,1 Msample (4 MB) 存储器用于波形回放
7, 1Msample (4 MB) 存储器用于波形保存
8,定制数字调制 (>15 种 FSK, MSK, PSK, QAM变异),AM, FM, 相位调制, 脉冲调制, 步进/表格扫描 (频率和功率),
9,GPIB 和 RS-232 连通能力
10,E443xB 性能升级
AgilentE4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437Bxinhao源简要:
供单信道和多信道CDMA用的测量zhuan用卡
用于I和Q的20 MHz射频带宽
j度高的电平
步进扫描(频率、功率和列表)
宽带调幅、调频和调相
内部数据发生器和突发脉冲功能(选件UN8)
灵活形成定制调制选件UN8,UND)
机内有供DECT、GSM、NADC、PDC、PHS和TETRA用的TDMA格式(选件UN8)
内部双任意波形发生器(选件UND)
内部误码率分析仪(选件UND7)
E4430B,E4431B,E4432B,E4433B,E4434B,E4435B,E4436,E4437B产品介绍:
安捷伦ESG-D/ESG-DP系列射频xinhao发生器除具有广f的特性和you良的模拟性能之外,还提供多种数字调制功能,而且在价格方面亦能被用户所接受。他们提供了j好的调制和wending度,电平。
安捷伦ESG-D/ESG-DP系列te别适于满足当前数字接shou机测试、元器件测试和本地振荡器应用日y提高的要求。
专门定制的调制和DECT、EDGE、GSM、NADC、PDC、PHS、TETRAbiao准(选件UN8)
内部生成通用biao准的xinhao来对接shou机进行测试。改变调制类型、数据、码元速率、滤波器型式和滤波因数,以生成供元器件和x1统容xian测试用的定制xinhao。很容易配置时隙来模拟不同类型的通信业wu量、控制信道或同步信道(或突发xinhao)。可产生具有内部突发功能y1动站或j1站传输。还降低了对具有综he数据sheng成功能的外部设备的需求。
内部双任意波开发生器(选件UND)
能重现几乎ren何以数学形式生成的波形。可xiazai长波形或多个波形(达1M取样),以放置或贮存到非易失RAM中供随后使用。14比特的数模转换器(DAC)分辨率扩大了动态范围和改善了噪声性能。在对I/Q生成进行you化后,双ren意波形发生器选件将使装置简化。
W-CDMA和Cdma 2000
能产生符合正在拟定的guo际biao准的正确编码xinhao。模拟用于ji站和移动接shou机测试的全编码信道或部分编码统计修正的多信道xinhao,可以对用于正在拟定的guo际3Gbiao准的有源元件进行jingque的大容量测试。
多信道和多载波CDMA
安捷伦ESG-D/ESG-DP系列提供CDMA(选件UN5)测量zhuan用卡。用多个信道产生多载波CDMAxinhao,每个载波用于j1站和移动zhan的x1统或元件测试。通过xuanze预定的多载波CDMA配置或明确确定每个信道对每个载波的特性,可以为某些te殊的需要,如互补累积分布函数(CCDF)专门制定某种测试。
内部误码率分析仪(选件UN7)
为测量灵敏度和xuanze性而进行误码率分析。选件UN7提供用于PN9或PN15比特序列的分析功能,并指出用户规定的测试j1限的he格或bu合ge条件。
宽带I和Q调制
l1用模拟I和Q输入,产生复杂的调制格式,以满足射频数字通信x1统开发研究和测试的需要。机内正交调制器处理I和Q输入xinhao,以在10MHz(1dB)带宽范围提供j1高的调制和wending度。
j1高的电平
安捷伦ESG-D/ESG-DP系列射频xinhao发生器能在宽的功率范围(+13dBm~-136dBm,利用选件UNB时为+17dBm~-136dBm)以j1高的电平进行jingque、有效的灵敏度测试。内部调制格式的电平优于±1.1dB(典型值为+0.6dB),从而保zheng甚至对zui灵敏的数字接shou机也能进行精密测量。
为你推荐
