--- 产品参数 ---
- 品牌 安捷伦Agilent
- 品牌 是德科技keysight
- 型号 N1913A
- 型号 N1914A
- 性能 计量合格
- 净重 5kg
- 品相 9成新
- 品名 单通道功率计
- 品名 双通道功率计
- 关联品牌 泰克
--- 产品详情 ---
N1913A,N1914A(EPM系列)脉冲带宽功率传感器:
N1913A单通道功率计,宽动态范围:-70 至 +44 dBm(取决于传感器) ,频率范围:9 kHz 至 110 GHz(取决于传感器)
N1914A双通道功率计,宽动态范围:-70 至 +44 dBm(取决于传感器),频率范围:9 kHz 至 110 GHz(取决于传感器)
是德科技N1913A,N1914A,可兼容一下系列传感器:
N1913A,N1914A 单双通道功率计与所有 N8480、8480、U2000 系列和 E 系列传感器(E9320 系列除外)兼容,
并提供 -70 至 +44 dBm、9 kHz 至 110 GHz 的平均功率测量。
功率主机:E4416A,E4417A,E4418A,E4419A,E4418B,E4419B,N1911A,N1912A,N1913A,N1914A。
![N1913A7.jpg](https://file1.elecfans.com/web2/M00/FD/A7/wKgaomaV6dCADRXjAACPW5-fA3E561.jpg)
![](https://file.elecfans.com/web2/M00/6C/39/poYBAGMu-DuAJXj4AABYApls6_M051.jpg)
N1913A,N1914A功率计特点:
1,频率范围:9 kHz 至 110 GHz(取决于传感器)
2,宽动态范围:-70 至 +44 dBm(取决于传感器)
3,速度提升至 E 系列传感器的两倍:高达 400 个读数/秒
4,不仅可提供 GPIB 连通性,还可提供 LAN LXI-C 和 USB 连通性
5,可与 E4418B、E4419B 功率计兼容
6,可与 436A、437B 和 438A 功率计兼容(选件 200)
7,更多的测量通道数:多达三个通道,使用可选的 USB 主机端口可连接另外两个 U2000 系列功率传感器
8,利用可选的外部触发输入/触发输出特性自动进行频率/功率扫描测量
![](https://file1.elecfans.com/web2/M00/FC/BE/wKgZomaV6dCAIR_DAAB72N3u99I301.jpg)
N1914B EPM Series Dual-Channel Power Meter
The N1914B EPM series dual-channel average power meter provides repeatable and reliable results for bench/rack and field applications.
Highlights
- Frequency range of DC to 120 GHz (sensor dependent)
- Wide dynamic range of -70 to +44 dBm (sensor dependent)
- Go beyond GPIB with LAN LXI-C and USB connectivity
- Backward compatible with N1913/14A EPM Series single/dual-channel average power meters
- Increased measurement channels: up to four channels with two additional U2000/U8480 Series and U2050/60 (except the peak power measurement) X-Series USB power sensors connected using the optional USB hosts
- Automated frequency/power sweep measurements with the optional external trigger in/out feature
- Your instrument now comes with the BenchVue Basic Power Meter/Sensor Control and Analysis App (BV0007B). The BenchVue software simplifies the process of connecting, controlling instruments, and automating test sequences. Download the BenchVue Basic App (BV0007B) for free to efficiently manage your power meter/sensor instruments
为你推荐
SMA100A与SMB100A还有SMC100A模拟信号发生器2024-09-28 12:12
产品型号:SMC100A,SMB100A,SMA100A 规格:139*238*0515cm 品牌:罗德与施瓦茨 品牌:是德科技 品牌:泰克 品牌:安立 -
B24前置放大选件FSV3030频谱分析仪2024-09-11 13:53
产品型号:FSV3030,FSV3044 品牌:罗德与施瓦茨 品牌:是德科技keysight 品牌:泰克tektronix 品牌:安立anritsu 品牌:安捷伦agilent -
射频13.6G信号分析仪 B710低相位噪声FSV30132024-09-03 22:06
产品型号:FSV3004,FSV3007,FSV3013 品牌:罗德与施瓦茨 品牌:安捷伦Agilent 品牌:是德科技keysight 品牌:泰克tektronix 型号:FSV3013 -
SMBV100B矢量信号发生器GNSS测试2G基带2024-09-03 17:44
产品型号:SMBV100B,SMCV100B 品牌:罗德与施瓦茨 品牌:安捷伦agilent 品牌:是德科技keysight 品牌:安立anritsu 品牌:泰克tektronix -
DC-18G机械校准件 是德科技85054D配合E5063A2024-09-03 14:12
产品型号:85054D 品牌:是德科技keysight 品牌:安捷伦Agilent 品牌:罗德与施瓦茨 品牌:泰克 品牌:安立 -
便携式6G机械步进衰减器 罗德与施瓦茨RSC2024-09-02 19:23
产品型号:RSC,8494B,8496B 品牌:罗德与施瓦茨R&S 品牌:是德科技keysight 品牌:安捷伦Agilent 品牌:泰克TEKTRONIX 型号:RSC -
高达67G毫米波信号源SMA100B带高功率选件B392024-09-02 17:50
产品型号:SMA100B 品牌:罗德与施瓦茨R7S 品牌:是德科技keysight 品牌:泰克tektronix 型号:SMA100B 品名:6G射频信号发生器 -
安捷伦E4981A-2M电容计-E4981A说明书2024-08-23 10:10
产品型号:E4981A-2M电容计 重量:25kg 品牌:安捷伦 品相:95新 -
是德LCR表-4263B操作说明2024-08-23 10:02
产品型号:4263B 重量:25kg 品牌:安捷伦 品相:95新 -
Agilent四通道高阻表4349B2024-08-23 09:55
产品型号:4349B 重量:25kg 品相:95新
