--- 产品参数 ---
- 台 1
--- 产品详情 ---
TYPE-81M12 多用途高性能带状光纤熔接机(可熔接芯数达12芯)
12芯带状光纤的熔接时间仅需14秒
双联自动独立加热器提高作业效率
全屏导航触摸界面实现简单操作
高速、便捷、可靠
12芯带状光纤的熔接时间仅约14秒,并且独立自动双联加热器实现加热补强时间约45秒(使用FPS-6热缩管的情况下),其加热器是业界*的功能,在ZG拥有。
人性化的全屏导航触摸界面和直观的图形用户界面
熔接机内置帮助视频,可在主机显示屏上播放
进一步提高了防振、防水、防尘以及防风等特性
可通过互联网进行软件升级和远程诊断
规格参数
TYPE-81M12 (更多信息请)
Applicable optical fiber | Material | Silica Glass |
Profile type | Single Mode Fiber (SMF)/ITU-T G652 Multi Mode Fiber (MMF)/ITU-T G651 Dispersion Shifted Fiber (DSF)/ITU-T G653 Non-Zero Dispersion Shifted Fiber (NZ-DSF)/ITU-T G655, G656 Bend Insensitive Fiber (BIF)/ITU-T G657 | |
Number of fiber *1 | 1c, 2c, 4c, 5c, 6c, 8c, 10c, 12c | |
Cladding diameter | φ125 μm | |
Coating diameter *2 | Single: 250 μm, 500 μm, 900 μm Ribbon fiber thickness: 280-400 μm | |
Cleave length | 10mm | |
Applicable cable | 0.25mm primary coated 1-fiber drop cable | 3.1mm or 2.6mm×2.0mm (Excluding messenger steel wire) |
0.25mm primary coated 1-fiber indoor cable | 2.0mm×1.6mm | |
Physical Characteristics | Size (Main body) | 120W×154D×130H(mm) *3 (4.7W×6.0D×5.1H(inches)) |
Weight | Approx. 2.0 kg (With Battery pack BU-11) | |
Display size | 4.1" touch screen color LCD display | |
Power Conditions | Power consumption | Max. 80W |
AC operation | With AC adapter ADC-1430S Input: AC 100-240V 50/60Hz 1.1A | |
DC operation | Input: DC 10-15V, 4.5A | |
Battery operation | (With BU-11) 11.1V (4600mAh) | |
DC output | 12V For Sumitomo’s hot jacket remover | |
In - Out Terminal | Serial port | USB 2.0 mini-B type |
Storage media | SD / SDHC memory card | |
Splice Performance at room temperature (25°C) | Splice loss (typical)*4 | SMF : 0.05 dB MMF: 0.02 dB DSF : 0.08 dB NZDSF : 0.08 dB |
Screening load (typical) | 1.96N - 2.09N (at stage) | |
Splice time (typical) | Approx. 14 seconds (SMF8-12c) Approx. 12 seconds (SMF4c) Approx. 9 seconds (SMF1c) | |
Splice & Heat cycles | Approx. 160 cycles *5 | |
Splice program | Maximum 200 fusion programs can be selected and customized. | |
Splice data storage | 10,000 splices | |
Splice image capture | 64 splices | |
Heater Performance | The number of heaters | 2 built-in heaters are available |
Sleeve length | Up to 60mm | |
Protection sleeve | Fiber protection sleeve | |
Up to 60mm sleeve | 60mm for single fiber (FPS-1, FPS-61-2.6) 40mm for ribbon up to 8c fiber (FPS-5) 40mm for ribbon up to 12c fiber (FPS-6, FPS-M12) Protection sleeve for Splice-on Connector(Single Fiber connector only) | |
Heating time(typical)*6 | Approx. 45 seconds. (40mm for 12c fiber) | |
Heating Program | Max. 100 settings | |
Environmental Conditions and Power Conditions | Operating temperature | -10 to +50°C |
Storage temperature | -40 to +80°C | |
Humidity | 0 to 95%RH with no dew present | |
Altitude | Up to 3,660 m | |
Environmental Durability | Shock resistance*7 | Drop from 76cm on 5 faces (Excluding top face) |
Water resistance*7 | Equivalent to IPx2 (Operates normally after being exposed to water dripping at 3mm/min. for at least 2.5 min on each of 4 surfaces tilted at 15 degree.) | |
Dust resistance*7 | Equivalent to IPx5 (Operates normally after 8 hours in a dust chamber containing dust of particle size 75 um or below) |
*1 光纤夹具需要符合涂覆层光纤和光纤芯数的要求。
*2 光纤夹具不能用于松套管光缆。
*3 突出的部分不包括在内。
*4 在室温条件下,用住友同种光纤以ITU-T和IEC标准的切断法测得。
*5 循环次数根据电池状态和操作环境不同也会随之变化。
*6 使用住友生产的保护套管在室温条件下,供电为AC电源适配器。
*7 住友对电池性能进行了试验和确认,但不保证本产品受损情况下的状态。
为你推荐
罗德与施瓦茨R&S RT-ZS10 RT-ZS10L RT-ZS10E有源探头2023-09-23 12:13
产品型号: RT-ZS10 RT-ZS10L RT-ZS10E 台:1 -
Keysight是德DP0002A MX0103A探头附件2023-07-01 10:25
产品型号:DP0002A MX0103A 台:1 -
泰克Tektronix OM70000光调制分析仪2023-07-01 10:24
产品型号:OM70000 台:1 -
Agilent 8753A 8753B 8753C 8753D网络分析仪2023-07-01 10:22
产品型号:8753A 8753B 8753C 8753D 台:1 -
Tektronix泰克AWG7102 AWG7082C任意波形发生器2023-07-01 10:21
产品型号:AWG7102 AWG7082C 台:1 -
加拿大EXFO FTB-500手持便捷式Pro测试平台2023-06-19 11:44
产品型号:EXFO FTB-500 台:1 -
Keysight是德M8920A E2142A JS-1500无线测试仪2023-02-28 08:59
产品型号:M8920A E2142A JS-1500 台:1 -
Keysight是德BT2152B BT2152A自放电分析仪2023-02-28 08:57
产品型号:BT2152B BT2152A 台:1 -
Newport RV350BPE-F 电机电动转台2023-02-28 08:53
产品型号:RV350BPE-F 台:1 -
Newport FCL200 FCL100 线性位移台2023-02-28 08:51
产品型号: FCL200 FCL100 台:1
