企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
深圳市美佳特科技有限公司
美佳特经营产品:光示波器眼图仪、可调谐激光源、光谱分析仪、光通信仪器等,为客户提供一站式解决方案与服务。
413 内容数 10w+ 浏览量 15 粉丝
AD5593RBCBZ-RL7 集成电路、处理器、微控制器 ADI(亚德诺) 封装N/A 批次21+
ADI
型号: AD5593RBCBZ-RL7
--- 产品参数 ---
  • 型号 AD5593RBCBZ-RL7
  • 封装 WLCSP16
  • 批次 21+
  • 制造商 Analog Devices Inc.
  • 通道数 8
  • 数据接口 I²C
  • 电压 - 供电 1.8V ~ 5.5V
  • 工作温度 -40°C ~ 105°C
  • 安装类型 表面贴装型
  • 封装/外壳 16-UFBGA,WLCSP
--- 产品详情 ---
Data Acquisition System Single ADC 8DAC 12Bit 16Pin WLCSP T/R
Product Details
The AD5593R has eight input/output (I/O) pins, which can be independently configured as digital-to-analog converter (DAC) outputs, analog-to-digital converter (ADC) inputs, digital outputs, or digital inputs. When an I/O pin is configured as an analog output, it is driven by a 12-bit DAC. The output range of the DAC is 0 V to VREF or 0 V to 2 × VREF. When an I/O pin is configured as an analog input, it is connected to a 12-bit ADC via an analog multiplexer. The input range of the ADC is 0 V to VREF or 0 V to 2 × VREF. The I/O pins can also be configured to be general-purpose, digital input or output (GPIO) pins. The state of the GPIO pins can be set or read back by accessing the GPIO write data register and GPIO read configuration registers, respectively, via an I2C write or read operation.
The AD5593R has an integrated 2.5 V, 20 ppm/°C reference that is turned off by default and an integrated temperature indicator that gives an indication of the die temperature. The temperature value is read back as part of an ADC read sequence.
The AD5593R is available in 16-lead TSSOP and LFCSP, as well as a 16-ball WLCSP, and operates over a temperature range of −40°C to +105°C.
为你推荐
  • keysight 34970/72A 相关模块功能说明2023-02-27 16:18
    您是否知道34970A/34972A不仅仅可以测量电压和温度?是的,DAQ带8个模块,每个模块都具有不同的功能,无需购买额外的设备来获得更多的功能,而是通过利用这些模块来节省时间。下面由小编我来给大家介绍一下,34970/72A相关模块及功能,这些模块可以进行常规DMM测量,以及温度测量。了解Agilent34903a/34904a模块,34903A是一个2
    1256浏览量
  • Agilent 34970A通过RS-232与PC之间的连接2023-02-27 11:49
    34970A有3个模块槽和8个开关与控制模块可配置,配合日常测试应用,同时34901A 20路继电器多路复用器时,34970A便成为紧凑的、低价位的数据记录器,适于实验室或现场的快速测试。有自引导菜单的直观面板和明亮的、便于阅读的真空显示使独立的设置既快又方便。所有读数都自动加有时间标记并存入-50,000读数的存储器
    1931浏览量
  • 34970a使用RS-232遇到问题-windows2023-02-27 11:44
    PC上使用的RS-232 I/O芯片(UART)只有16字节缓冲器。在没有实时流量控制时,可能会发生缓冲器超限,导致数据丢失。如果丢失的字符恰好是线路输入,软件一直没有看到行尾结束符,从而可能会导致超时。其它字符丢失可能会导致返回的数据错误。34970A
    1311浏览量
  • 深圳市美佳特科技有限公司|专注仪器测量,助力企业产品发展2022-08-04 13:52
    在5G技术的快速发展的背景下,通信技术的落地催生更多的应用场景。在长远规划的发展战略中,深圳市美佳特科技有限公司将一直保持对行业敏锐的洞察力,他们会持续深耕5G、半导体、新能源和智能制造等新兴产业方向测试测量应用,为客户提供高可靠、高易用性、高性价比的解决方案,继续突破技术,用科技让生活更美好!自2010年成立以来, 深圳市美佳特科技有限公司为企业提供以测试
    701浏览量
  • 美佳特新官网即将上线—用科技让世界更美好2022-08-01 11:39
    深圳市美佳特科技有限公司,始终致力于光通讯测试、通用电子测量及5G测试领域,凭借丰富的技术经验、高端的测试仪器、完善的服务体系,为客户提供功能领先且极具高性价比的测试测量解决方案。 为了适应公司长期发展,美佳特科技加强企业文化建设和对外宣传的要求,按照“简洁、大气、易用、美观”的原则对公司网站进行了全新设计。新版官网融合、完善了原网站的部分内容,
    522浏览量
  • 什么是示波器?示波器的原理,应用范围?2022-07-28 11:37
    示波器是一种能显示电压信号动态波形的测试计量仪器。将时变的电压信号在时域上转换成曲线,将原来看不见的电信号在二维平面上转换成直观的可见光信号,因此可以分析电信号的时域性质。更先进的示波器甚至可以分析输入时间信号的频谱,反映输入信号的频域特征。常见测量仪器有M8195A 、N1092C、MS9740A、AQ6317B、86100C、MP2100B
    3325浏览量
  • 安捷伦Agilent 86100C 光宽带宽示波器(眼图仪)2022-07-06 10:00
    86100系列为光接口和电接口波形的各种数据速率的测试设计了一系列插件模块。 86100 可以容纳最多两个模块, 支持总共 4 条测量通道。86100C 支持广泛的模块, 可以同时测试光信号和电接口信号。 用户可以选择适合的模块, 获得所需的特定带宽、 滤波功能和灵敏度。码型锁定触发加强了采样示波器的功能
    1946浏览量
  • 86142B 安捷伦Keysight 86142B高性能光谱分析仪2022-07-06 09:29
    Keysight 86142B是一款台式光谱分析仪(OSA),最适于对功率和波长精度、动态范围和低偏振敏感性都要求非常严格的WDM元件和系统测试应用。它将高性能和先进特性集及板上测量应用结合在一起,为您提供精确、快速、简易的测量。这些先进特性得到了精心定制,旨在提高您生产效率及制造能力,并降低制造成本。板上测量应用可在根据个人需要保持定制测量灵活性的同时,简
    1030浏览量
  • M8195A Keysight是德 65 GSa/s 任意波形发生器2022-06-30 16:43
    是德公司(NYSE:KEYS)日前推出一款高达 92 GSa/s、32 GHz 带宽的模块化仪器,作为现有任意波形发生器家族的补充。全新的高速、高带宽 M8195A 任意波形发生器允许工程师以 8 位垂直分辨率生成数字多电平(例如 PAM4、PAM-8、DMT)信号场景,并利用速率高达 64 GBaud 的复合调制信号来测试电和光链路。这使得 M8195A
    752浏览量
  • MS9740A-安立(Anritsu)全新台式光谱分析仪2022-06-20 09:51
    日本安立MS9740A是一台覆盖600nm到1750nm的台式光谱分析仪,它提供高性能光分辨率和高速测量以支持元件和器件生产商的需求。波形数据可以在0.2s内测量并发送给外部控制设备—这个速度是安立以前型号的5倍。光谱分析仪MS9740A减少了从波形扫描到数据转发给外部控制设备总的时间,使分析过程简单化,能提供高性价比和更高的产能。
    1699浏览量
