--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Max) (V) | 36 |
Vs (Min) (V) | 3 |
Input offset (+/-) (Max) (uV) | 150 |
Gain (Min) (V/V) | 1 |
Gain (Max) (V/V) | 1000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 18 |
Features | Cost Optimized, Small Size, Overvoltage Protection |
CMRR (Min) (dB) | 120 |
Input offset drift (+/-) (Max) (uV/C) | 2 |
Input bias current (+/-) (Max) (nA) | 65 |
Iq (Typ) (mA) | 0.2 |
Bandwidth at min gain (Typ) (MHz) | 1 |
Gain error (+/-) (Max) (%) | 0.15 |
Operating temperature range (C) | -40 to 125 |
Type | Resistor |
Output swing headroom (to negative supply) (Typ) (V) | 0.1 |
Output swing headroom (to positive supply) (Typ) (V) | -0.15 |
Input common mode headroom (to negative supply) (Typ) (V) | 0 |
Input common mode headroom (to positive supply) (Typ) (V) | -1 |
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) | 0.52 |
Gain non-linearity (+/-) (Max) (%) | 0.002 |
- Input common-mode range: Includes V–
- Common-mode rejection:
- 104 dB, min (G = 10)
- 100 dB, min at 5 kHz (G = 10)
- Power-supply rejection: 100 dB, min (G = 1)
- Low offset voltage: 150 μV, max
- Gain drift: 1 ppm/°C (G = 1), 35 ppm/°C (G > 1)
- Noise: 18 nV/√Hz, G ≥ 100
- Bandwidth: 1 MHz (G = 1), 60 kHz (G = 100)
- Inputs protected up to ±40 V
- Rail-to-rail output
- Supply current: 200 μA
- Supply range:
- Single supply: 3 V to 36 V
- Dual supply: ±1.5 V to ±18 V
- Specified temperature range:
–40°C to +125°C - Packages: 8-pin VSSOP, SOIC, and WSON
The INA826 is a cost-effective instrumentation amplifier that offers extremely low power consumption and operates over a very wide single-supply or dual-supply range. A single external resistor sets any gain from 1 to 1000. The device offers excellent stability over temperature, even at G > 1, as a result of the low gain drift of only 35 ppm/°C (maximum).
The INA826 is optimized to provide excellent common-mode rejection ratio of over 100 dB (G = 10) over frequencies up to 5 kHz. At G = 1, the common-mode rejection ratio exceeds 84 dB across the full input common-mode range, from the negative supply all the way up to 1 V of the positive supply. Using a rail-to-rail output, the INA826 is a great choice for low-voltage operation from a 3-V single supply, as well as dual supplies up to ±18 V.
Additional circuitry protects the inputs against overvoltage of up to ±40 V beyond the power supplies by limiting the input currents to less than 8?mA.
The INA826 is available in 8-pin SOIC, VSSOP, and tiny 3-mm × 3-mm WSON surface-mount packages. All versions are specified for the –40°C to +125°C temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
