--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Max) (V) | 5.5 |
Vs (Min) (V) | 1.8 |
Input offset (+/-) (Max) (uV) | 25 |
Gain (Min) (V/V) | 1 |
Gain (Max) (V/V) | 1000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 50 |
Features | Zero Drift, Low power |
CMRR (Min) (dB) | 80 |
Input offset drift (+/-) (Max) (uV/C) | 0.1 |
Input bias current (+/-) (Max) (nA) | 0.2 |
Iq (Typ) (mA) | 0.198 |
Bandwidth at min gain (Typ) (MHz) | 0.15 |
Gain error (+/-) (Max) (%) | 0.5 |
Operating temperature range (C) | -55 to 210 |
Type | Resistor |
Output swing headroom (to negative supply) (Typ) (V) | 0.05 |
Output swing headroom (to positive supply) (Typ) (V) | -0.05 |
Input common mode headroom (to negative supply) (Typ) (V) | 0.1 |
Input common mode headroom (to positive supply) (Typ) (V) | -0.1 |
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) | 2 |
Gain non-linearity (+/-) (Max) (%) | 0.001 |
- Low Offset Voltage: 25 μV (max at 25°C), G ≥ 100
- Low Drift: 0.2 μV/°C, G ≥ 1000
- Low Noise: 55 nV/√Hz, G ≥ 100
- High CMRR: 100 dB (min at 25°C), G ≥ 10
- Supply Range: +1.8 V to +5.5 V
- Input Voltage: (V–) +0.1 V to (V+) –0.1 V
- Output Range: (V–) +0.05 V to (V+) –0.05V
- Low Quiescent Current: 198 μA
- RFI Filtered Inputs
The INA333 is a low-power, precision instrumentation amplifier offering excellent accuracy. The versatile 3-op amp design, small size, and low power make it ideal for a wide range of portable applications.
A single external resistor sets any gain from 1 to 1000. The INA333 is designed to use an industry-standard gain equation: G = 1 + (100kΩ/RG).
The INA333 provides very low offset voltage (25 μV at 25°C, G ≥ 100), excellent offset voltage drift (0.2 μV/°C, G?≥?100), and high common-mode rejection (100 dB at 25°C, G?≥?10). It operates with power supplies as low as 1.8 V (±0.9V), and quiescent current is only 50 μA—ideal for battery-operated systems. Using autocalibration techniques to ensure excellent precision over the extended industrial temperature range, the INA333 also offers exceptionally low noise density (55 nV/√Hz) that extends down to dc.
The INA333 is is specified over the TA?=?–55°C to +210°C temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
