--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Max) (V) | 36 |
Vs (Min) (V) | 9 |
Input offset (+/-) (Max) (uV) | 250 |
Gain (Min) (V/V) | 2000 |
Gain (Max) (V/V) | 2000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 1.3 |
Features | Ultra-low noise |
CMRR (Min) (dB) | 100 |
Input bias current (+/-) (Max) (nA) | 12000 |
Iq (Typ) (mA) | 10 |
Bandwidth at min gain (Typ) (MHz) | 0.45 |
Gain error (+/-) (Max) (%) | 1 |
Operating temperature range (C) | -55 to 125 |
Type | Fixed Gain |
Output swing headroom (to negative supply) (Typ) (V) | 1.8 |
Output swing headroom (to positive supply) (Typ) (V) | -1.8 |
Input common mode headroom (to negative supply) (Typ) (V) | 3 |
Input common mode headroom (to positive supply) (Typ) (V) | -3 |
Gain non-linearity (+/-) (Max) (%) | 0.005 |
- LOW NOISE: 1.3nV/Hz at 1kHz
- LOW THD+N: 0.09% at 1kHz
- WIDE BANDWIDTH: 450kHz
- WIDE SUPPLY RANGE: ±4.5V to ±18V
- HIGH CMR: > 100dB
- GAIN SET WITH EXTERNAL RESISTOR
- SO-14 SURFACE-MOUNT PACKAGE
- APPLICATIONS
- MOVING-COIL TRANSDUCER AMPLIFIERS
- DIFFERENTIAL RECEIVERS
- BRIDGE TRANSDUCER AMPLIFIERS
- MICROPHONE AND HYDROPHONE PREAMPS
The INA166 is a very low-noise, low-distortion, monolithic instrumentation amplifier. Its current-feedback circuitry achieves very wide bandwidth and excellent dynamic response over a wide range of gain. It is ideal for low-level signals such as microphones or hydrophones. Many industrial, instrumentation, and medical applications also benefit from its low noise and wide bandwidth.
Unique distortion cancellation circuitry reduces distortion to extremely low levels, even in high gain. The INA166 provides near-theoretical noise performance for 200 source impedance. Its differential input, low noise, and low distortion provide superior performance as a low-level signal amplifier.
The INA166 is available in a space-saving SO-14 surface-mount package, specified for operation over the \x9640°C to +85°C temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
