--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Max) (V) | 36 |
Vs (Min) (V) | 2.2 |
Input offset (+/-) (Max) (uV) | 250 |
Gain (Min) (V/V) | 5 |
Gain (Max) (V/V) | 10000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 60 |
Features | Low power |
CMRR (Min) (dB) | 83 |
Input offset drift (+/-) (Max) (uV/C) | 3 |
Input bias current (+/-) (Max) (nA) | 25 |
Iq (Typ) (mA) | 0.06 |
Bandwidth at min gain (Typ) (MHz) | 0.12 |
Gain error (+/-) (Max) (%) | 0.5 |
Operating temperature range (C) | -40 to 85 |
Type | Resistor |
Output swing headroom (to negative supply) (Typ) (V) | 0.1 |
Output swing headroom (to positive supply) (Typ) (V) | -0.05 |
Input common mode headroom (to negative supply) (Typ) (V) | 0 |
Input common mode headroom (to positive supply) (Typ) (V) | -1.6 |
Noise at 0.1 Hz-10 Hz (Typ) (uVpp) | 2 |
Gain non-linearity (+/-) (Max) (%) | 0.002 |
- LOW QUIESCENT CURRENT: 60μA
- WIDE POWER SUPPLY RANGE
- Single Supply: 2.2V to 36V
- Dual Supply: -0.9/+1.3V to ±18V
- COMMON-MODE RANGE to (V-)-0.1V
- RAIL-TO-RAIL OUTPUT SWING
- LOW OFFSET VOLTAGE: 250μV max
- LOW OFFSET DRIFT: 3μV/°C max
- LOW NOISE: 60nV/sqrt(Hz)
- LOW INPUT BIAS CURRENT: 25nA max
- 8-PIN DIP AND SO-8 SURFACE-MOUNT
The INA122 is a precision instrumentation amplifier for accurate, low noise differential signal acquisition. Its two-op-amp design provides excellent performance with very low quiescent current, and is ideal for portable instrumentation and data acquisition systems.
The INA122 can be operated with single power supplies from 2.2V to 36V and quiescent current is a mere 60μA. It can also be operated from dual supplies. By utilizing an input level-shift network, input common-mode range extends to 0.1V below negative rail (single supply ground).
A single external resistor sets gain from 5V/V to 10000V/V. Laser trimming provides very low offset voltage (250μV max), offset voltage drift (3μV/°C max) and excellent common-mode rejection.
Packages options include 8-pin plastic DIP and SO-8 surface-mount packages. Both are specified for the -40°C to +85°C extended industrial temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
