--- 产品详情 ---
Number of channels (#) | 1 |
Vs (Max) (V) | 50 |
Vs (Min) (V) | 18 |
Input offset (+/-) (Max) (uV) | 250 |
Gain (Min) (V/V) | 1 |
Gain (Max) (V/V) | 1000 |
Noise at 1 kHz (Typ) (nV/rt (Hz)) | 1 |
Features | Current Feedback, Ultra-low noise |
CMRR (Min) (dB) | 100 |
Input bias current (+/-) (Max) (nA) | 12000 |
Iq (Typ) (mA) | 9 |
Bandwidth at min gain (Typ) (MHz) | 6 |
Gain error (+/-) (Max) (%) | 0.25 |
Operating temperature range (C) | -40 to 85 |
Type | Resistor |
Output swing headroom (to negative supply) (Typ) (V) | 3 |
Output swing headroom (to positive supply) (Typ) (V) | -3 |
Input common mode headroom (to negative supply) (Typ) (V) | 3 |
Input common mode headroom (to positive supply) (Typ) (V) | -3 |
Gain non-linearity (+/-) (Max) (%) | 0.004 |
- LOW NOISE: 1nV/sqrt(Hz)
- LOW THD+N: 0.0009% at 1kHz, G = 100
- HIGH GBW: 100MHz at G = 1000
- WIDE SUPPLY RANGE: ±9V to ±25V
- HIGH CMRR: >110dB
- BUILT-IN GAIN SETTING RESISTORS: G = 1, 100
- UPGRADES AD625
The INA103 is a very low noise, low distortion monolithic instrumentation amplifier. Its current-feedback circuitry achieves very wide bandwidth and excellent dynamic response. It is ideal for low-level audio signals such as balanced low-impedance microphones. The INA103 provides near-theoretical limit noise performance for 200(ohm) source impedances. Many industrial applications also benefit from its low noise and wide bandwidth.
Unique distortion cancellation circuitry reduces distortion to extremely low levels, even in high gain. Its balanced input, low noise and low distortion provide superior performance compared to transformer-coupled microphone amplifiers used in professional audio equipment.
The INA103?s wide supply voltage (±9 to ±25V) and high output current drive allow its use in high-level audio stages as well. A copper lead frame in the plastic DIP assures excellent thermal performance.
The INA103 is available in 16-pin plastic DIP, 16-pin ceramic DIP and SOL-16 surface-mount packages. Commercial and industrial temperature range models are available.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
