--- 产品详情 ---
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
BW @ Acl (MHz) | 36 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 220 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 10 |
Iq per channel (Typ) (mA) | 0.25 |
Rail-to-rail | Out |
Vos (offset voltage @ 25 C) (Max) (mV) | 1 |
Operating temperature range (C) | -40 to 125 |
Output current (Typ) (mA) | 26 |
2nd harmonic (dBc) | 128 |
3rd harmonic (dBc) | 137 |
Frequency of harmonic distortion measurement (MHz) | 0.001 |
GBW (Typ) (MHz) | 30 |
Input bias current (Max) (pA) | 210000 |
Features | Shutdown |
CMRR (Typ) (dB) | 116 |
Rating | Catalog |
- Ultra Low Power:
- Voltage: 2.5 V to 5.5 V
- Current: 250 μA
- Power-Down Mode: 0.5 μA (typical)
- Fully-Differential Architecture
- Bandwidth: 36 MHz
- Slew Rate: 200 V/μs
- THD: –120 dBc at 1 kHz (1 VRMS, RL= 2 k?)
- Input Voltage Noise: 10 nV/√Hz (f = 1 kHz)
- High DC Accuracy:
- VOS Drift: ±4 μV/?C (–40°C to +125°C)
- AOL: 114 dB
- Rail-to-Rail Output (RRO)
- Negative Rail Input (NRI)
- Output Common-Mode Control
The THS4531 is a low-power, fully-differential op amp with input common-mode range below the negative rail and rail-to-rail output. The device is designed for low-power data acquisition systems and high density applications where power consumption and dissipation is critical.
The device features accurate output common-mode control that allows for dc coupling when driving analog-to-digital converters (ADCs). This control, coupled with the input common-mode range below the negative rail and rail-to-rail output, allows for easy interface from single-ended ground-referenced signal sources to successive-approximation registers (SARs), and delta-sigma (ΔΣ) ADCs using only single-supply 2.5 V to 5 V power. The THS4531 is also a valuable tool for general-purpose, low-power differential signal conditioning applications.
The THS4531 is characterized for operation over the extended industrial temperature range from –40°C to +125°C. The following package options are available:
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
