--- 产品详情 ---
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
BW @ Acl (MHz) | 118 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 507 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 4.6 |
Iq per channel (Typ) (mA) | 18 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Operating temperature range (C) | -40 to 85 |
Output current (Typ) (mA) | 36 |
2nd harmonic (dBc) | 124.7 |
3rd harmonic (dBc) | 114.7 |
Frequency of harmonic distortion measurement (MHz) | 0.001 |
GBW (Typ) (MHz) | 118 |
Input bias current (Max) (pA) | 2000000 |
Features | Shutdown, Adjustable BW/IQ/IOUT |
CMRR (Typ) (dB) | 90 |
Rating | Catalog |
- Differential Input and Output
- Tri-Level Power Settings with Shutdown
- Ultra Low HD2/HD3 and THD+N Distortion
- Adjustable Output Common-Mode Level
- Fully-Balanced Differential Architecture
- Single- or Dual-Supply Operation
- Operating Voltage Range 4.5 V to 12 V
- Supply Current 3 mA to 13 mA
- Total THD+N at 1 KHz 0.000097%
- HD2 / HD3 Distortion at 1 KHz < –124 dBc
- Bandwidth 118 mHz
- Settling to 0.1% 20 ns
- Low Offset Drift 0.4 μV/°C
- Offset Voltage 80 μV
- Voltage Noise 4.6 nV/Hz
- Operating Temperature Range ?40°C to +85°C
All trademarks are the property of their respective owners.
The LMP8350 device is an ultra low distortion fully-differential amplifier designed for driving high-performance precision analog-to-digital converters (ADC). As part of the PowerWise family, a unique mode enable pin allows the user to choose from three different operating modes, trading power consumption for dynamic performance.
The high power mode is optimized for highest AC performance. The low noise, wide bandwidth, and fast slew rate make the LMP8350 ideal for driving 24-bit ADCs with input sampling rates of 10 MHz or less. The medium power mode is optimized for precision DC performance, and can be used to drive 24-bit ADCs with input sampling rates of 6 MHz or less. The low power mode is a trade-off between AC performance and quiescent current for power-sensitive applications. The disable mode fully shuts down the amplifier for further standby power savings.
The fully differential architecture of this device allows for easy implementation of a single-ended to fully-differential output conversion. Driving a 3-Vpp, 1-kHz output sine wave with the amplifier powered by ±3.3-V rails in high power mode yields 0.000098% THD+N.
The LMP8350 is part of the LMP precision amplifier family, and is offered in the 8-pin SOIC package, with an operating temperature range of ?40°C to +85°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
