--- 产品详情 ---
具有断电功能的高速全差分放大器
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 15 |
BW @ Acl (MHz) | 370 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 2800 |
Architecture | Fully Differential ADC Driver, Bipolar |
Vn at flatband (Typ) (nV/rtHz) | 6.8 |
Iq per channel (Typ) (mA) | 23 |
Rail-to-rail | No |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Operating temperature range (C) | -40 to 85, 0 to 70 |
Output current (Typ) (mA) | 120 |
2nd harmonic (dBc) | 83 |
3rd harmonic (dBc) | 97 |
Frequency of harmonic distortion measurement (MHz) | 8 |
GBW (Typ) (MHz) | 300 |
Input bias current (Max) (pA) | 4600000 |
Features | Shutdown |
CMRR (Typ) (dB) | 80 |
Rating | Catalog |
- Fully Differential Architecture
- Bandwidth: 370 MHz
- Slew Rate: 2800 V/μs
- IMD3: -95 dBc at 30 MHz
- OIP3: 51 dBm at 30 MHz
- Output Common-Mode Control
- Wide Power Supply Voltage Range: 5 V, ±5 V, 12 V, 15 V
- Centered Input Common-Mode Range
- Power-Down Capability (THS4502)
- Evaluation Module Available
The THS4502 and THS4503 are high-performance fully differential amplifiers from Texas Instruments. The THS4502, featuring power-down capability, and the THS4503, without power-down capability, set new performance standards for fully differential amplifiers with unsurpassed linearity, supporting 14-bit operation through 40 MHz. Package options include the 8-pin SOIC and the 8-pin MSOP with PowerPAD for a smaller footprint, enhanced ac performance, and improved thermal dissipation capability.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
