--- 产品详情 ---
具有关断状态的 3.3 V 100MHz 43 V/us 全差动 CMOS 放大器
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 3.5 |
BW @ Acl (MHz) | 100 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 55 |
Architecture | Fully Differential ADC Driver, High Input Impedance |
Vn at flatband (Typ) (nV/rtHz) | 5.4 |
Iq per channel (Typ) (mA) | 11 |
Rail-to-rail | In to V+, Out |
Vos (offset voltage @ 25 C) (Max) (mV) | 8 |
Operating temperature range (C) | -40 to 85, 0 to 70 |
Output current (Typ) (mA) | 25 |
2nd harmonic (dBc) | 79 |
3rd harmonic (dBc) | 93 |
Frequency of harmonic distortion measurement (MHz) | 1 |
GBW (Typ) (MHz) | 100 |
Input bias current (Max) (pA) | 1.2 |
Features | Shutdown |
CMRR (Typ) (dB) | 96 |
Rating | Catalog |
- High Performance
- 100 MHz –3 dB Bandwidth
- 50 V/μs Slew Rate
- –75 dB Total Harmonic Distortion at 1 MHz (VO = 2 VPP)
- 5.4 nV/Hz Input-Referred Noise (10 kHz)
- Differential Input/Differential Output
- Balanced Outputs Reject Common-Mode Noise
- Differential Reduced Second Harmonic Distortion
- Power Supply Range
- VDD = 3.3 V
- KEY APPLICATIONS
- Simple Single-Ended To Differential Conversion
- Differential ADC Driver/Differential Antialiasing
- Differential Transmitter And Receiver
- Output Level Shifter
PowerPAD is a trademark of Texas Instruments.
The THS412x is one in a family of fully differential-input, differential-output devices fabricated using Texas Instruments? state-of-the-art submicron CMOS process.
The THS412x consists of a true fully-differential signal path from input to output. This results in excellent common-mode noise rejection and improved total harmonic distortion.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
