--- 产品详情 ---
Common mode voltage (Max) (V) | 80 |
Common mode voltage (Min) (V) | 10 |
Input offset (+/-) (Max) (uV) | 300 |
Gain (V/V) | 1, 0.5 |
Gain error (%) | 1.25 |
Bandwidth (kHz) | 0.5 |
Supply voltage (Max) (V) | 80 |
Supply voltage (Min) (V) | 10 |
Iq (Max) (mA) | 6.8 |
Digital interface | I2C, PMBus, SMBus |
Features | Digital Temp Monitor |
Resolution (Bits) | 12 |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
- Input Voltage Range: 10 V to 80 V
- Real-Time Monitoring of VIN, IIN, PIN, VOUT, and VAUX with 12-bit resolution, 1-kHz sampling rate
- True input Power Measurement using simultaneous sampling of Vin and Iin
- Remote Temperature Sensing with programmable warning thresholds
- Power Measurement Accuracy
- LM5056A: ±1.75%
- LM5056: ±2.25%
- Current Measurement Accuracy
- LM5056A: ±1.25%
- LM5056: ±1.5%
- Voltage Measurement Accuracy: ±1.0%
- Averaging of VIN, IIN, PIN, and VOUT with Programmable Interval Ranging from 0.001 s to 4 s
- Programmable WARN and FAULT Thresholds with SMBA Notification
- Black-Box Capture of Telemetry Measurements and Device Status Triggered by WARN or FAULT Condition
- I2C/SMBus Interface and PMBus Compliant Command Structure
PMBus is a trademark of Texas Instruments.
The LM5056/LM5056A combines high-performance analog and digital technology with a PMBus compliant SMBus? and I2C interface to accurately measure the electrical operating conditions of systems connected to a backplane power bus. The LM5056/LM5056A continuously supplies real-time power, voltage, current, temperature and fault data to the system management host via the SMBus interface.
The LM5056/LM5056A monitoring block computes both the real time and average values of subsystem operating parameters (VIN, IIN, PIN, VOUT) as well as the peak power. Accurate power averaging is accomplished by averaging the product of the input voltage and current. A black-box (telemetry and fault snapshot) function captures and stores telemetry data and device status in the event of a warning or a fault.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
