--- 产品详情 ---
增强型产品 -16V 至 80V、500kHz 电流感应放大器
Common mode voltage (Max) (V) | 80 |
Common mode voltage (Min) (V) | -16 |
Input offset (+/-) (Max) (uV) | 2000 |
Input offset drift (+/-) (Typ) (uV/C) | 2.5 |
Gain (V/V) | 20 |
Gain error (%) | 1 |
Gain error drift (+/-) (Max) (ppm/°C) | 100 |
CMRR (Min) (dB) | 100 |
Bandwidth (kHz) | 500 |
Supply voltage (Max) (V) | 18 |
Supply voltage (Min) (V) | 2.7 |
Iq (Max) (mA) | 1.3 |
Number of channels (#) | 1 |
Comparators (#) | 0 |
Features | Low-side Capable |
Rating | HiRel Enhanced Product |
Operating temperature range (C) | -55 to 125 |
- Wide Common-Mode Voltage:
–16 V to 80 V - Low Error: 3.0% Over Temp (Max)
- Bandwidth: Up to 500 kHz
- Three Transfer Functions Available: 20 V/V,
50 V/V, and 100 V/V - Complete Current Sense Solution
The INA193A current shunt monitors with voltage output can sense drops across shunts at common-mode voltages from –16 V to 80 V, independent of the INA19x supply voltage. They are available with three output voltage scales: 20 V/V, 50 V/V, and 100 V/V. The 500-kHz bandwidth simplifies use in current control loops.
The INA193A operates from a single 2.7-V to 18-V supply, drawing a maximum of 1300-μA of supply current. It is specified over the extended operating temperature range (–55°C to 125°C), and is offered in a space-saving SOT23 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
