--- 产品详情 ---
Number of channels (#) | 1 |
Output type | Push-pull |
Propagation delay time (μs) | 36 |
Vs (Max) (V) | 16 |
Vs (Min) (V) | 2.7 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Iq per channel (Typ) (mA) | 0.00056 |
Input bias current (+/-) (Max) (nA) | 0.1 |
Rail-to-rail | In |
Rating | Automotive |
Operating temperature range (C) | -40 to 125 |
VICR (Max) (V) | 21 |
VICR (Min) (V) | -0.1 |
- Qualified for Automotive Applications
- ESD Protection Exceeds 2000 V Per MIL-STD-883, Method 3015; Exceeds 200 V Using Machine Model (C = 200 pF, R = 0)
- Low Supply Current ...560 nA/Per Channel
- Input Common-Mode Range Exceeds the Rails ...–0.1 V to VCC + 5 V
- Supply Voltage Range ...2.7 V to 16 V
- Reverse Battery Protection Up to 18 V
- Push-Pull CMOS Output Stage
- Specified Temperature Range
- –40°C to 125°C - Automotive Grade
- Ultrasmall Packaging
- 5-Pin SOT-23 (TLV3701)
- Universal Op-Amp EVM (Reference SLOU060 for more information)
- APPLICATIONS
- Low Power Automotive Systems
- Security Detection Systems
The TLV370x is Texas Instruments? first family of nanopower comparators with only 560 nA per channel supply current, which make this device ideal for low power applications.
The TLV370x has a minimum operating supply voltage of 2.7 V over the extended temperature range
(TA = ?40°C to 125°C), while having an input common-mode range of ?0.1 to VCC + 5 V. The low supply current makes it an ideal choice for low power applications where quiescent current is the primary concern. Reverse battery protection guards the amplifier from an over-current condition due to improper battery installation. For harsh environments, the inputs can be taken 5 V above the positive supply rail without damage to the device.
Devices are available in SOIC with the singles in the small SOT-23 package. Other package options may be made available upon request.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
