--- 产品详情 ---
Number of channels (#) | 1 |
Output type | Open-collector |
Propagation delay time (μs) | 6 |
Vs (Max) (V) | 5.5 |
Vs (Min) (V) | 1.8 |
Vos (offset voltage @ 25 C) (Max) (mV) | 12 |
Iq per channel (Typ) (mA) | 0.0028 |
Input bias current (+/-) (Max) (nA) | 0.01 |
Rail-to-rail | In |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
Features | Internal Reference, Small Size |
VICR (Max) (V) | 5.7 |
VICR (Min) (V) | -0.2 |
- LOW QUIESCENT CURRENT: 5μA (max)
- INTEGRATED VOLTAGE REFERENCE: 1.242V
- INPUT COMMON-MODE RANGE:
???200mV Beyond Rails - VOLTAGE REFERENCE INITIAL ACCURACY: 1%
- OPEN-DRAIN LOGIC COMPATIBLE OUTPUT:
???TLV3011 - PUSH-PULL OUTPUT: TLV3012
- LOW-SUPPLY VOLTAGE: 1.8V to 5.5V
- FAST RESPONSE TIME: 6μs Propagation Delay with 100mV Overdrive (TLV3011: RPULL-UP = 10k)
- MicroSIZE PACKAGES: SOT23-6 and SC70-6
- APPLICATIONS
- BATTERY-POWERED LEVEL DETECTION
- DATA ACQUISITION
- SYSTEM MONITORING
- OSCILLATORS
- SENSOR SYSTEMS:
???Smoke Detectors, Light Sensors, Alarms
All trademarks are the property of their respective owners.
The TLV3011 is a low-power, open-drain output comparator;the TLV3012 is a push-pull output comparator. Both feature an uncommitted on-chip voltage reference. Both have 5μA (max) quiescent current, input common-mode range 200mV beyond the supply rails, and single-supply operation from 1.8V to 5.5V. The integrated 1.242V series voltage reference offers low 100ppm/°C (max) drift, is stable with up to 10nF capacitive load, and can provide up to 0.5mA (typ) of output current.
The TLV3011 and TLV3012 are available in the tiny SOT23-6 package for the most space-conservative designs. It is also available in the SC70 package for even greater board area savings. Both versions are specified for the temperature range of ?40°C to +125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
