--- 产品详情 ---
Number of channels (#) | 4 |
Output type | Open-collector, Open-drain |
Propagation delay time (μs) | 1.3 |
Vs (Max) (V) | 36 |
Vs (Min) (V) | 2 |
Vos (offset voltage @ 25 C) (Max) (mV) | 2 |
Iq per channel (Typ) (mA) | 0.2 |
Input bias current (+/-) (Max) (nA) | 25 |
Rail-to-rail | Out |
Rating | Space |
Operating temperature range (C) | -55 to 125 |
VICR (Max) (V) | 34.5 |
VICR (Min) (V) | 0 |
- QML-V Qualified, SMD 5962-7700801VCA, 5962-9673802VCA
and 5962-9673802V9B - Rad-Tolerant: 40 kRad/sec (Si) TID
(5962-9673802VCA and 5962-9673802V9B)(1)- TID Dose Rate = 0.01 rad/sec (Si)
- Wide Supply Ranges
- Single Supply: 2 V to 36 V
(Tested to 30 V) - Dual Supplies: ±1 V to ±18 V
(Tested to ±15 V)
- Low Supply-Current Drain Independent of Supply Voltage:
0.8 mA (Typ) - Low Input Bias Current: 25 nA (Typ)
- Low Input Offset Current: 3 nA (Typ) (LM139)
- Low Input Offset Voltage: 2 mV (Typ)
- Common-Mode Input Voltage Range Includes Ground
- Differential Input Voltage Range Equal to Maximum-Rated
Supply Voltage: ±36 V - Low Output Saturation Voltage
- Output Compatible With TTL, MOS, and CMOS
(1) Radiation tolerance is a typical value based upon initial device qualification with dose rate = 0.01 rad/sec. Radiation lot acceptance testing is available - contact factory for details.
These devices consist of four independent voltage comparators that are designed to operate from a single power supply over a wide range of voltages. Operation from dual supplies also is possible, as long as the difference between the two supplies is 2?V to 36 V, and VCC is at least 1.5 V more positive than the input common-mode voltage. Current drain is independent of the supply voltage. The outputs can be connected to other open-collector outputs to achieve wired-AND relationships.
The LM139 and LM139A are characterized for operation over the full military temperature range of –55°C to 125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
