--- 产品详情 ---
Number of channels (#) | 4 |
Output type | Open-collector, Open-drain |
Propagation delay time (μs) | 1 |
Vs (Max) (V) | 16 |
Vs (Min) (V) | 4 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Iq per channel (Typ) (mA) | 0.011 |
Input bias current (+/-) (Max) (nA) | 0.03 |
Rail-to-rail | Out |
Rating | Military |
Operating temperature range (C) | -55 to 125 |
VICR (Max) (V) | 15 |
VICR (Min) (V) | 0 |
- Very Low Power . . . 200 μW Typ at 5 V
- Fast Response Time . . . 2.5 μs Typ With 5-mV Overdrive
- Single Supply Operation:
- TLC139M . . . 4 V to 16 V
- TLC339M . . . 4 V to 16 V
- TLC339C . . . 3 V to 16 V
- TLC339I . . . 3 V to 16 V
- High Input Impedance . . . 1012 Typ
- Input Offset Voltage Change at Worst Case Input at Condition Typically 0.23 μV/Month Including the First 30 Days
- On-Chip ESD Protection
LinCMOS is a trademark of Texas Instruments Incorporated.
The TLC139/TLC339 consists of four independent differential-voltage comparators designed to operate from a single supply. It is functionally similar to the LM139/LM339 family but uses 1/20th the power for similar response times. The open-drain MOS output stage interfaces to a variety of leads and supplies, as well as wired logic functions. For a similar device with a push-pull output configuration, see the TLC3704 data sheet.
The Texas Instruments LinCMOS? process offers superior analog performance to standard CMOS processes. Along with the standard CMOS advantages of low power without sacrificing speed, high input impedance, and low bias currents, the LinCMOS? process offers extremely stable input offset voltages, even with differential input stresses of several volts. This characteristic makes it possible to build reliable CMOS comparators.
The TLC139M and TLC339M are characterized for operation over the full military temperature range of ?55°C to 125°C. The TLC339C is characterized for operation over the commercial temperature range of 0°C to 70°C. The TLC339I is characterized for operation over the industrial temperature range of ?40°C to 85°C. The TLC339Q is characterized for operation over the extended industrial temperature range of ?40°C to 125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
