--- 产品详情 ---
Number of channels (#) | 2 |
Output type | Open-collector, Open-drain |
Propagation delay time (μs) | 1 |
Vs (Max) (V) | 16 |
Vs (Min) (V) | 4 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Iq per channel (Typ) (mA) | 0.011 |
Input bias current (+/-) (Max) (nA) | 0.03 |
Rail-to-rail | Out |
Rating | Military |
Operating temperature range (C) | -55 to 125 |
VICR (Max) (V) | 15 |
VICR (Min) (V) | 0 |
- Very Low Power...110 μW Typ at 5 V
- Fast Response Time...tPLH = 2.5 μs Typ With 5-mV Overdrive
- Single Supply Operation:
??????TLC393C...3 V to 16 V
??????TLC393I...3 V to 16 V
??????TLC393Q...4 V to 16 V
??????TLC393M...4 V to 16 V
??????TLC193M...4 V to 16 V - On-Chip ESD Protection
LinCMOS is a trademark of Texas Instruments Incorporated.
The TLC193 and TLC393 consist of dual independent micropower voltage comparators designed to operate from a single supply. They are functionally similar to the LM393 but uses one-twentieth the power for similar response times. The open-drain MOS output stage interfaces to a variety of loads and supplies. For a similar device with a push-pull output configuration (see the TLC3702 data sheet).
Texas Instruments LinCMOS? process offers superior analog performance to standard CMOS processes. Along with the standard CMOS advantages of low power without sacrificing speed, high input impedance, and low bias currents, the LinCMOS? process offers ex-tremely stable input offset voltages, even with differential input stresses of several volts. This characteristic makes it possible to build reliable CMOS comparators.
The TLC393C is characterized for operation over the commercial temperature range of TA = 0°C to 70°C. The TLC393I is characterized for operation over the extended industrial temperature range of TA = ?40°C to 85°C. The TLC393Q is characterized for operation over the full automotive temperature range of TA = ?40°C to 125°C. The TLC193M and TLC393M are characterized for operation over the full military temperature range of TA = ?55°C to 125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
