--- 产品详情 ---
Number of channels (#) | 1 |
Output type | Open-collector |
Propagation delay time (μs) | 1.2 |
Vs (Max) (V) | 30 |
Vs (Min) (V) | 3.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 7.5 |
Iq per channel (Typ) (mA) | 0.15 |
Input bias current (+/-) (Max) (nA) | 100 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | -25 to 85 |
Features | Strobe, Vos Adj Pin |
VICR (Max) (V) | 28.5 |
VICR (Min) (V) | 0.5 |
- Low Power Drain . . . 900 μW Typical With 5-V Supply
- Operates From ±15 V or From a Single Supply as Low as 3 V
- Output Drive Capability of 25 mA
- Emitter Output Can Swing Below Negative Supply
- Response Time . . . 1.2 μs Typ
- Low Input Currents:
???????Offset Current ...2 nA Typ
???????Bias Current . . . 15 nA Typ - Wide Common-Mode Input Range:
- –14.5 V to 13.5 V Using ±15-V Supply
- Same Pinout as LM211, LM311
- Designed To Be Interchangeable With Industry Standard LP311
The LP211 and LP311 devices are low-power versions of the industry-standard LM211 and LM311 devices. They take advantage of stable, high-value, ion-implanted resistors to perform the same function as the LM311 series, with a 30:1 reduction in power consumption but only a 6:1 slowdown in response time. They are well suited for battery-powered applications and all other applications where fast response times are not needed. They operate over a wide range of supply voltages, from ±18 V down to a single 3-V supply with less than 300-μA current drain, but are still capable of driving a 25-mA load. The LP211 and LP311 are quite easy to apply free of oscillation if ordinary precautions are taken to minimize stray coupling from the output to either input or to the trim pins. In addition, offset balancing is available to minimize input offset voltage. Strobe capability is also provided to turn off the output (regardless of the inputs) by pulling the strobe pin low.
The LP211 is characterized for operation from ?25°C to 85°C. The LP311 is characterized for operation from 0°C to 70°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
