--- 产品详情 ---
具有选通信号的 140ns 差分比较器
Number of channels (#) | 1 |
Output type | Differential |
Propagation delay time (μs) | 0.14 |
Vs (Max) (V) | 32 |
Vs (Min) (V) | 11 |
Vos (offset voltage @ 25 C) (Max) (mV) | 1 |
Iq per channel (Typ) (mA) | 13 |
Input bias current (+/-) (Max) (nA) | 30000 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | 0 to 70 |
Features | Strobe |
VICR (Max) (V) | 23 |
VICR (Min) (V) | 9 |
- Independent strobes
- Ensured high speed:?20 ns max
- Tight delay matching on both outputs
- Complementary TTL outputs
- Operates from op amp supplies:?±15V
- Low speed variation with overdrive variation
- Low input offset voltage
- Versatile supply voltage range
All trademarks are the property of their respective owners.
The LM161/LM361 is a very high speed differential input, complementary TTL output voltage comparator with improved characteristics over the SE529/NE529 for which it is a pin-for-pin replacement. The device has been optimized for greater speed performance and lower input offset voltage. Typically delay varies only 3 ns for over-drive variations of 5 mV to 500 mV. It may be operated from op amp supplies (±15V).
Complementary outputs having maximum skew are provided. Applications involve high speed analog to digital converters and zero-crossing detectors in disk file systems.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
