--- 产品详情 ---
Number of channels (#) | 4 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.004 |
GBW (Typ) (MHz) | 5 |
Features | EMI Hardened, MUX Friendly, Zero Drift |
Slew rate (Typ) (V/us) | 10 |
Rail-to-rail | Out |
Offset drift (Typ) (uV/C) | 0.003 |
Iq per channel (Typ) (mA) | 0.85 |
Vn at 1 kHz (Typ) (nV/rtHz) | 5.7 |
CMRR (Typ) (dB) | 168 |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
Input bias current (Max) (pA) | 350 |
Output current (Typ) (mA) | 65 |
Architecture | CMOS |
THD + N @ 1 kHz (Typ) (%) | 0.00008 |
- Ultra-high precision:
- Zero-drift: 0.003 μV/°C
- Ultra-low offset voltage: 4 μV (maximum)
- Excellent dc precision:
- CMRR: 168 dB
- Open-loop gain: 170 dB
- Low noise:
- en at 1 kHz: 5.7 nV/√Hz
- 0.1-Hz to 10-Hz noise: 0.12 μVPP
- Excellent dynamic performance:
- Gain bandwidth: 5 MHz
- Slew rate: 10 V/μs
- Fast settling: 10-V step, 0.01% in 1.7 μs
- Robust design:
- MUX-friendly inputs
- RFI and EMI filtered inputs
- Wide supply: ±2.25 V to ±18 V, 4.5 V to 36 V
- Quiescent current: 0.85 mA
- Rail-to-rail output
- Input includes negative rail
The OPA182, OPA2182, and OPA4182 (OPAx182) are ultra-low noise, fast-settling, zero-drift, high-precision operational amplifiers, These devices provide rail-to-rail output operation and feature a unique MUX-friendly architecture and controlled start-up system. These devices also feature excellent ac performance combined with only 0.45 μV of offset voltage and 0.003 μV/°C of drift over temperature. All these features make the OPAx182 a great choice for data acquisition, battery test, analog input modules, weigh scales, and any other systems requiring high dc precision and low noise.
The MUX-friendly input architecture prevents inrush current when applying large input differential voltages and improves settling performance in multichannel systems. Moreover, the controlled start-up system rejects any inrush current when ramping up the supply rails, all while providing robust ESD protection during shipment, handling, and assembly.
The device is specified from –40°C to +125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
