--- 产品详情 ---
Number of channels (#) | 4 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.003 |
GBW (Typ) (MHz) | 14 |
Features | EMI Hardened, High Cload Drive, Zero Drift |
Slew rate (Typ) (V/us) | 20 |
Rail-to-rail | Out |
Offset drift (Typ) (uV/C) | 0.005 |
Iq per channel (Typ) (mA) | 1.3 |
Vn at 1 kHz (Typ) (nV/rtHz) | 5.2 |
CMRR (Typ) (dB) | 168 |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
Input bias current (Max) (pA) | 500 |
Output current (Typ) (mA) | 65 |
Architecture | CMOS |
THD + N @ 1 kHz (Typ) (%) | 0.00006 |
- Ultra-high precision:
- Zero-drift: 0.005 μV/°C (OPA189)
- Ultra-low offset voltage: 3 μV maximum (OPA189)
- Excellent dc precision:
- CMRR: 168 dB
- Open-loop gain: 170 dB
- Low noise:
- en at 1 kHz: 5.2 nV/√Hz
- 0.1-Hz to 10-Hz noise: 0.1 μVPP
- Excellent dynamic performance:
- Gain bandwidth: 14 MHz
- Slew rate: 20 V/μs
- Fast settling: 10-V step, 0.01% in 1.1 μs
- Robust design:
- MUX-friendly inputs
- RFI/EMI filtered inputs
- Wide supply range: 4.5 V to 36 V
- Quiescent current: 1.7 mA (maximum)
- Rail-to-rail output
- Input includes negative rail
The OPA189, OPA2189, and OPA4189 (OPAx189) high-precision operational amplifiers are ultra-low noise, fast-settling, zero-drift devices that provide rail-to-rail output operation and feature a unique MUX-friendly architecture and controlled start-up system. These features and excellent ac performance, combined with only 0.4 μV of offset voltage and 0.005μV/°C of drift over temperature for the single-channel version, make the OPAx189 a great choice for precision instrumentation, signal measurement, and active filtering applications. Moreover, the MUX-friendly input architecture prevents inrush current when applying large input differential voltages, which improves settling performance in multichannel systems, all while providing robust ESD protection during shipment, handling, and assembly.
All versions are specified from –40°C to +125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
