--- 产品详情 ---
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 24 |
Output current (Typ) (mA) | 450 |
GBW (Typ) (MHz) | 21 |
Slew rate (Typ) (V/us) | 50 |
Vos (offset voltage @ 25 C) (Max) (mV) | 25 |
Offset drift (Typ) (uV/C) | 15 |
Iq per channel (Typ) (mA) | 3.6 |
Features | Adj Current Limit, EMI Hardened, High Cload Drive, Shutdown |
Rating | Automotive |
Operating temperature range (C) | -40 to 125 |
TI functional safety category | Functional Safety-Capable |
Input bias current (Max) (pA) | 100 |
CMRR (Typ) (dB) | 94 |
Rail-to-rail | In, Out |
Architecture | Bipolar |
- AEC-Q100 qualified for automotive applications:
- Temperature grade 1: –40°C to +125°C, TA
- Functional-safety capable
- Documentation available to aid functional safety system design
- High output current drive: 650 mA, peak (per channel)
- Replaces discrete op amps and transistors
- Wide supply range for both supplies (up to 24 V)
- Overtemperature shutdown
- Current limit
- Shutdown pin for low IQ applications
- 21-MHz gain bandwidth with 50-V/μs slew rate
- Package: 14-pin HTSSOP (PWP)
The ALM2403-Q1 is a dual-power op amp with features and performance that make this device preferable for resolver-based applications. The high-gain bandwidth and slew rate of the device, along with a continuous high-output current-drive capability, make this device an excellent choice to provide the low distortion and differential high-amplitude excitation required for exciting the resolver primary coil. Current limiting and overtemperature detection enhance overall system robustness, especially when driving analog signals over wires that are susceptible to faults.
The small HTSSOP package with thermal pad and low RθJA allows high currents to be delivered to loads while minimizing board space. The higher gain bandwidth of the ALM2403-Q1 allows the device to be configured as a filter stage while still providing high output drive, thus significantly reducing the total solution size of a resolver drive signal chain. This reduced solution size is a key advantage offered by the ALM2403-Q1 when used in automotive and industrial applications.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
