--- 产品详情 ---
Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 1.8 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.15 |
GBW (Typ) (MHz) | 17 |
Slew rate (Typ) (V/us) | 9.5 |
Rail-to-rail | In to V-, Out |
Offset drift (Typ) (uV/C) | 1.75 |
Iq per channel (Typ) (mA) | 1.3 |
Vn at 1 kHz (Typ) (nV/rtHz) | 5.8 |
CMRR (Typ) (dB) | 100 |
Rating | Automotive |
Operating temperature range (C) | -40 to 125 |
Input bias current (Max) (pA) | 1 |
Output current (Typ) (mA) | 23 |
Architecture | CMOS |
THD + N @ 1 kHz (Typ) (%) | 0.001 |
- Unless Otherwise Noted, Typical Values at VS = 5V.
- Renewable Energy Grade
- Input Offset Voltage ±150 μV (max)
- Input Bias Current 100 fA
- Input Voltage Noise 5.8 nV/√Hz
- Gain Bandwidth Product 17 MHz
- Supply Current 1.30 mA
- Supply Voltage Range 1.8V to 5.5V
- THD+N @ f = 1 kHz 0.001%
- Operating Temperature Range ?40°C to 125°C
- Rail-to-rail Output Swing
- 8-Pin VSSOP Package
All trademarks are the property of their respective owners.
The SM73307 is a dual, low noise, low offset, CMOS input, rail-to-rail output precision amplifier with a high gain bandwidth product. The SM73307 is ideal for a variety of instrumentation applications including solar photovoltaic.
Utilizing a CMOS input stage, the SM73307 achieves an input bias current of 100 fA, an input referred voltage noise of 5.8 nV/√Hz, and an input offset voltage of less than ±150 μV. These features make the SM73307 a superior choice for precision applications.
Consuming only 1.30 mA of supply current per channel, the SM73307 offers a high gain bandwidth product of 17 MHz, enabling accurate amplification at high closed loop gains.
The SM73307 has a supply voltage range of 1.8V to 5.5V, which makes it an ideal choice for portable low power applications with low supply voltage requirements.
The SM73307 is built with TI’s advanced VIP50 process technology and is offered in an 8-pin VSSOP package.
The SM73307 incorporates enhanced manufacturing and support processes for the photovoltaic and automotive market, including defect detection methodologies. Reliability qualification is compliant with the requirements and temperature grades defined in the Renewable Energy Grade and AEC-Q100 standards.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
