--- 产品详情 ---
| Number of channels (#) | 1 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 1.8 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 0.01 |
| GBW (Typ) (MHz) | 0.35 |
| Features | EMI Hardened, Zero Drift |
| Slew rate (Typ) (V/us) | 0.16 |
| Rail-to-rail | In, Out |
| Offset drift (Typ) (uV/C) | 0.02 |
| Iq per channel (Typ) (mA) | 0.017 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 55 |
| CMRR (Typ) (dB) | 130 |
| Rating | Automotive |
| Operating temperature range (C) | -40 to 125 |
| Input bias current (Max) (pA) | 200 |
| Output current (Typ) (mA) | 5 |
| Architecture | CMOS |
- AEC-Q100 qualified for automotive applications:
- Temperature grade 1: –40°C to +125°C, TA
- Low offset voltage: 10 μV (maximum)
- 0.01-Hz to 10-Hz noise: 1.1 μVPP
- Quiescent current: 17 μA
- Single-supply operation
- Supply voltage: 1.8 V to 5.5 V
- Rail-to-rail input and output
- Microsize 5-pin SOT-23 (DBV) package
The OPA333-Q1 CMOS operational amplifier uses a proprietary autocalibration technique to simultaneously provide verylow offset voltage (10 μV maximum) and near-zero drift over time and temperature. This miniature, high-precision, low-quiescent-current amplifier offers high-impedance inputs that have a common-mode range 100 mV beyond the rails, and rail-to-rail output that swings within 50 mV of the rails. The device can use single or dual supplies as low as 1.8 V (±0.9 V) and up to 5.5 V (±2.75 V), and is optimized for low-voltage single-supply operation.
The OPA333-Q1 device offers excellent common-mode rejection ratio (CMRR) without the crossover associated with traditional complementary input stages. This design results in superior performance for driving analog-to-digital converters (ADCs) without degradation of differential linearity.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
