--- 产品详情 ---
Number of channels (#) | 1 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.18 |
GBW (Typ) (MHz) | 45 |
Features | Shutdown |
Slew rate (Typ) (V/us) | 27 |
Rail-to-rail | Out |
Offset drift (Typ) (uV/C) | 0.35 |
Iq per channel (Typ) (mA) | 3.6 |
Vn at 1 kHz (Typ) (nV/rtHz) | 1.1 |
CMRR (Typ) (dB) | 120 |
Rating | High Temp |
Operating temperature range (C) | -55 to 210 |
Input bias current (Max) (pA) | 200000 |
Output current (Typ) (mA) | 30 |
Architecture | Bipolar |
THD + N @ 1 kHz (Typ) (%) | 0.000015 |
- Low Voltage Noise: 1.1 nV/√Hz at 1 kHz
- Input Voltage Noise:
80 nVPP (0.1 Hz to 10 Hz) - THD+N: –136dB (G = 1, f = 1 kHz)
- Offset Voltage: 240 μV (max)
- Offset Voltage Drift: 0.35 μV/°C (typ)
- Low Supply Current: 6 mA/Ch (typ)
- Unity-Gain Stable
- Gain Bandwidth Product:
80 MHz (G = 100)
45 MHz (G = 1) - Slew Rate: 27 V/μs
- 16-Bit Settling: 700 ns
- Wide Supply Range:
±2.25 V to ±18 V, 4.5 V to 36 V - Rail-to-rail output
- Output current: 30 mA
- APPLICATIONS
- Down-Hole Drilling
- High Temperature Environments
- APPLICATIONS
- Controlled Baseline
- One Assembly/Test Site
- One Fabrication Site
- Available in Extreme (–55°C/210°C)
Temperature Range(1) - Extended Product Life Cycle
- Extended Product-Change Notification
- Product Traceability
- Texas Instruments high temperature products
utilize highly optimized silicon (die)
solutions with design and process enhancements
to maximize performance over extended
temperatures.
(1) Custom temperature ranges available
All other trademarks are the property of their respective owners
The OPA211 series of precision operational amplifiers achieves very low 1.1 nV/√Hz noise density with a supply current of only 3.6 mA. This series also offers rail-to-rail output swing, which maximizes dynamic range.
The extremely low voltage and low current noise, high speed, and wide output swing of the OPA211 series make these devices an excellent choice as a loop filter amplifier in PLL applications.
In precision data acquisition applications, the OPA211 series of op amps provides 700-ns settling time to 16-bit accuracy throughout 10-V output swings. This ac performance, combined with only 240-μV of offset and 0.35-μV/°C of drift over temperature, makes the OPA211 ideal for driving high-precision 16-bit analog-to-digital converters (ADCs) or buffering the output of high-resolution digital-to-analog converters (DACs).
The OPA211 series is specified over a wide dual-power supply range of ±2.25 V to ±18 V, or for single-supply operation from 4.5 V to 36 V.
This series of op amps is specified from TA = –55°C to 210°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
