--- 产品详情 ---
Architecture | Fixed Gain/Buffer |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 7 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 13 |
GBW (Typ) (MHz) | 500 |
BW @ Acl (MHz) | 500 |
Acl, min spec gain (V/V) | 2 |
Slew rate (Typ) (V/us) | 2675 |
Vn at flatband (Typ) (nV/rtHz) | 6.1 |
Vn at 1 kHz (Typ) (nV/rtHz) | 6.1 |
Iq per channel (Typ) (mA) | 32 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 66 |
Input bias current (Max) (pA) | 50 |
Offset drift (Typ) (uV/C) | 10 |
Output current (Typ) (mA) | 70 |
2nd harmonic (dBc) | 75 |
3rd harmonic (dBc) | 96 |
Frequency of harmonic distortion measurement (MHz) | 10 |
- HIGH BANDWIDTH: 500 MHz (G = +2 V/V)
- HIGH SLEW RATE: 2675 V/μs (4-V Step)
- EXCELLENT THD: –71dBc at 10 MHz
- LOW INPUT VOLTAGE NOISE: 6.1 nV/√Hz
- FAST OVERDRIVE RECOVERY: 8 ns
- FAST SETTLING TIME (1% 4-V Step): 7.9 ns
- LOW INPUT OFFSET VOLTAGE: ±1 mV
- LOW INPUT BIAS CURRENT: ±10 pA
- HIGH INPUT IMPEDANCE: 1012 ||2.5 pF
- INTERNAL GAIN SETTING RESISTORS:
G = +2 V/V or G = –1 V/V - HIGH OUTPUT CURRENT: 70 mA
- APPLICATIONS
- TEST AND MEASUREMENT FRONT-END
- HIGH-INPUT IMPEDANCE PROBES
- DATA ACQUISITION CARDS
- OSCILLOSCOPE INPUT
- ADC INPUT AMPLIFIER
All trademarks are the property of their respective owners.
The OPA653 combines a very wideband voltage-feedback operational amplifier with a JFET-input stage with internal gain setting resistors to achieve an ultra-high, dynamic-range amplifier for fixed gain of +2-V/V or –1-V/V applications.
The 500-MHz wide gain of +2-V/V bandwidth is complemented by a very high 2675-V/μs slew rate and fast settling time that make it ideal for time-domain and pulse-oriented applications.
Excellent –72-dBc THD distortion performance at 10 MHz makes the OPA653 an excellent choice for frequency-domain and FFT analysis applications.
Additionally, with the low 6.1-nV/√Hz voltage noise, low bias current, and high impedance JFET input, it supports very low noise, wideband, high input impedance applications. Examples include high-impedance probes, data acquisition cards, and oscilloscope front-ends.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
