--- 产品详情 ---
Architecture | Current FB |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3.5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
GBW (Typ) (MHz) | 1100 |
BW @ Acl (MHz) | 1100 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 2900 |
Vn at flatband (Typ) (nV/rtHz) | 1.8 |
Vn at 1 kHz (Typ) (nV/rtHz) | 1.8 |
Iq per channel (Typ) (mA) | 12.9 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3.5 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 56 |
Input bias current (Max) (pA) | 30000000 |
Offset drift (Typ) (uV/C) | 15 |
Output current (Typ) (mA) | 120 |
2nd harmonic (dBc) | 73 |
3rd harmonic (dBc) | 82 |
Frequency of harmonic distortion measurement (MHz) | 10 |
- GAIN = +2V/V BANDWIDTH (850MHz)
- GAIN = +8V/V BANDWIDTH (450MHz)
- OUTPUT VOLTAGE SWING: ±4.1V
- ULTRA-HIGH SLEW RATE: 2900V/μs
- DIFFERENTIAL 3RD-ORDER INTERCEPT:
> 40dBm (f < 140MHz, 800 ) - LOW POWER: 129mW/channel
- LOW DISABLED POWER: 0.5mW/channel
- APPLICATIONS
- VERY WIDEBAND ADC DRIVERS
- LOW-COST PRECISION IF AMPLIFIERS
- BROADBAND VIDEO LINE DRIVERS
- PORTABLE INSTRUMENTS
- ACTIVE FILTERS
- ARB WAVEFORM OUTPUT DRIVERS
PowerPAD is a trademark of Texas Instruments, Inc.
All other trademarks are the property of their respective owners.
The OPA2695 is a dual, very high bandwidth, current-feedback op amp that combines exceptional 2900V/μs slew rate and low input voltage noise to deliver a precision, low-cost, high dynamic range intermediate frequency (IF) amplifier. The device has been optimized for high gain operation, and the pin outs of the two available packages (QFN-16, SO-8) have been optimized to provide symmetrical input and output paths. This architecture makes the OPA2695 an ideal choice as a differential driver, such as for a high-speed analog-to-digital converter (ADC).
The OPA2695 low 12.9mA/channel supply current is precisely trimmed at +25°C. This trim, along with a low temperature drift, gives low system power over temperature. System power may be further reduced with the optional disable control pin. Leaving this pin open, or holding it high, gives normal operation. If pulled low, the OPA2695 supply current drops to less than 200μA/channel. This power-saving feature, along with exceptional single +5V operation, makes the OPA2695 ideal for portable applications. The OPA2695 is available in an SO-8 (without disable) package or QFN-16 package (with disable).
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
