--- 产品详情 ---
Architecture | Current FB |
Number of channels (#) | 3 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 3.5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
GBW (Typ) (MHz) | 1000 |
BW @ Acl (MHz) | 1000 |
Acl, min spec gain (V/V) | 2 |
Slew rate (Typ) (V/us) | 2400 |
Vn at flatband (Typ) (nV/rtHz) | 1.8 |
Vn at 1 kHz (Typ) (nV/rtHz) | 1.8 |
Iq per channel (Typ) (mA) | 12.9 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3.5 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 56 |
Input bias current (Max) (pA) | 30000000 |
Offset drift (Typ) (uV/C) | 15 |
Output current (Typ) (mA) | 120 |
2nd harmonic (dBc) | 65 |
3rd harmonic (dBc) | 86 |
Frequency of harmonic distortion measurement (MHz) | 10 |
- 900MHz BANDWIDTH, GAIN = +2V/V
- 450MHz BANDWIDTH, GAIN = +8V/V
- WIDE OUTPUT VOLTAGE SWING: ±4V
- ULTRA-HIGH SLEW RATE: 4300V/μs
- 3RD-ORDER INTERCEPT: > 35dBm (f < 40MHz)
- LOW 1.8nV/√Hz VOLTAGE NOISE
- ±120mA OUTPUT CURRENT DRIVE
- 12.9mA/Ch SUPPLY CURRENT (±5V)
- LOW 0.1mA/Ch DISABLE CURRENT
- 3.5V to 12V SINGLE-SUPPLY OPERATION
- ±1.75V to ±6V SPLIT-SUPPLY OPERATION
- APPLICATIONS
- BROADBAND VIDEO LINE DRIVERS
- VERY WIDEBAND ADC DRIVERS
- HIGH BANDWIDTH INSTRUMENTATION AMPLIFIERS
- HIGH-SPEED IMAGING
- ACTIVE FILTERS
- ARB WAVEFORM OUTPUT DRIVERS
All other trademarks are the property of their respective owners
The OPA3695 is a triple, very high bandwidth, current-feedback opamp that combines an exceptional 4300V/μs slew rate and a very high 900MHz bandwidth (G = +2V/V) to provide an amplifier that is ideal for the most demanding video applications. The device versatility is enhanced with a low 1.8nV/√Hz input voltage noise and an output stage that can swing within 1V from the supply rail to deliver a high dynamic range signal, making it well-suited for analog-to-digital converter (ADC) front-ends or digital-to-analog converter (DAC) output buffering. Optimized for high gain operation, the OPA3695 is also well-suited for buffering surface acoustic wave (SAW) filters in an intermediate frequency (IF) system.
The low 12.9mA/channel supply current is precisely trimmed at +25°C. This trim, along with a low temperature drift, gives low system power over temperature. System power may be further reduced using the Disable control pin. Leaving this pin open, or holding it high, gives normal operation. If pulled low, the OPA3695 supply current drops to 100μA/channel. This power-saving feature, along with exceptional single +5V operation, makes the OPA3695 a good fit for low-power applications that require very high performance. The OPA3695 is available in an SSOP-16 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
