--- 产品详情 ---
Automotive-grade, dual, 30-V, 3-MHz, 13-V/μs slew rate, In to V+, JFET-input op amp
Number of channels (#) | 2 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 30 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 7 |
Rail-to-rail | In to V+ |
GBW (Typ) (MHz) | 3 |
Slew rate (Typ) (V/us) | 13 |
Vos (offset voltage @ 25 C) (Max) (mV) | 6 |
Iq per channel (Typ) (mA) | 1.4 |
Vn at 1 kHz (Typ) (nV/rtHz) | 18 |
Rating | Automotive |
Operating temperature range (C) | -40 to 125, -40 to 85 |
Offset drift (Typ) (uV/C) | 18 |
Features | Standard Amps |
Input bias current (Max) (pA) | 200 |
CMRR (Typ) (dB) | 86 |
Output current (Typ) (mA) | 10 |
Architecture | FET |
- Qualified for Automotive Applications
- Low Power Consumption
- Wide Common-Mode and Differential Voltage Ranges
- Low Input Bias and Offset Currents
- Low Total Harmonic Distortion: 0.003% Typ
- High Input Impedance: JFET-Input Stage
- Latchup-Free Operation
- High Slew Rate: 13 V/μs Typ
- Common-Mode Input Voltage Range Includes VCC+
The TL082 JFET-input operational amplifier incorporates well-matched, high-voltage JFET and bipolar transistors in a monolithic integrated circuit. The device features high slew rates, low input bias and offset currents, and low offset-voltage temperature coefficient.
The I-suffix device is characterized for operation from -40°C to 85°C. The Q-suffix device is characterized for operation from -40°C to 125°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
