--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.6 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
GBW (Typ) (MHz) | 115 |
BW @ Acl (MHz) | 115 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 250 |
Vn at flatband (Typ) (nV/rtHz) | 8.4 |
Vn at 1 kHz (Typ) (nV/rtHz) | 8.4 |
Iq per channel (Typ) (mA) | 0.46 |
Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
Rail-to-rail | No |
Features | Shutdown |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 70 |
Input bias current (Max) (pA) | 750000 |
Offset drift (Typ) (uV/C) | 20 |
Output current (Typ) (mA) | 40 |
2nd harmonic (dBc) | 75 |
3rd harmonic (dBc) | 80 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- FLEXIBLE SUPPLY RANGE:
+2.6V to +12V Single Supply
±1.3V to ±6V Dual Supplies - UNITY-GAIN STABLE
- WIDEBAND ±5V OPERATION: 60MHz
(G = +2V/V) - OUTPUT VOLTAGE SWING: ±4V
- HIGH SLEW RATE: 250V/μs
- LOW QUIESCENT CURRENT: 460μA/ch
- LOW DISABLE CURRENT: 18μA/ch
- APPLICATIONS
- VIDEO LINE DRIVING
- xDSL LINE RECEIVERS
- HIGH-SPEED IMAGING CHANNELS
- ADC BUFFERS
- PORTABLE INSTRUMENTS
- TRANSIMPEDANCE AMPLIFIERS
- ACTIVE FILTERS
All other trademarks are the property of their respective owners.
The OPA2889 represents a major step forward in unity-gain stable, voltage-feedback op amps. A new internal architecture provides slew rate and full-power bandwidth previously found only in wideband, current-feedback op amps. These capabilities give exceptional full-power bandwidth. Using a dual ±5V supply, the OPA2889 can deliver a ±4V output swing with over 40mA drive current and 60MHz bandwidth. This combination of features makes the OPA2889 an ideal RGB line driver or single-supply analog-to-digital converter (ADC) input driver or low power twisted pair line receiver.
The low 460μA/ch supply current of the OPA2889 is precisely trimmed at +25°C. System power may be reduced further using the optional disable control pin. Leaving this disable pin open, or holding it HIGH, operates the OPA2889 normally. If pulled LOW, the OPA2889 supply current drops to less than 20μA/ch while the output goes into a high-impedance state.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
