--- 产品详情 ---
Diff gain (%) | 0.025 |
Output current (Typ) (mA) | 70 |
Vs (Min) (V) | 5 |
Vs (Max) (V) | 5 |
Diff phase (deg) | 0.025 |
Operating temperature range (C) | -40 to 85 |
Rating | Catalog |
- 700MHz SMALL-SIGNAL BANDWIDTH
(AV = +2) - 425MHz, 4VPP BANDWIDTH
- 0.1dB GAIN FLATNESS to 200MHz
- 4ns CHANNEL SWITCHING TIME
- LOW SWITCHING GLITCH: 40mVPP
- 3100V/μs SLEW RATE
- 0.025%/0.025° DIFFERENTIAL GAIN, PHASE
- HIGH GAIN ACCURACY: 2.0V/V ±0.4%
- APPLICATIONS
- RGB SWITCHING
- LCD PROJECTOR INPUT SELECT
- WORKSTATION GRAPHICS
- ADC INPUT MUX
- DROP-IN UPGRADE TO LT1675-1
All other trademarks are the property of their respective owners.
The OPA875 offers a very wideband, single-channel 2:1 multiplexer in an SO-8 or a small MSOP-8 package. Using only 11mA, the OPA875 provides a gain of +2 video amplifier channel with greater than 425MHz large-signal bandwidth (4VPP). Gain accuracy and switching glitch are improved over earlier solutions using a new input stage switching approach. This technique uses current steering as the input switch while maintaining an overall closed-loop design. With greater than 700MHz small-signal bandwidth at a gain of 2, the OPA875 gives a typical 0.1dB gain flatness to greater than 200MHz.
System power may be reduced using the chip enable feature for the OPA875. Taking the chip enable line high powers down the OPA875 to less than 300μA total supply current. Muxing multiple OPA875 outputs together, then using the chip enable to select which channels are active, increases the number of possible inputs.
Where three channels are required, consider using the OPA3875 for the same level of performance.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
