--- 产品详情 ---
Number of channels (#) | 1 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 1.8 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.15 |
GBW (Typ) (MHz) | 17 |
Slew rate (Typ) (V/us) | 10.43 |
Rail-to-rail | In to V-, Out |
Offset drift (Typ) (uV/C) | 1.5 |
Iq per channel (Typ) (mA) | 1.3 |
Vn at 1 kHz (Typ) (nV/rtHz) | 6.5 |
CMRR (Typ) (dB) | 100 |
Rating | Catalog |
Operating temperature range (C) | -40 to 125 |
Input bias current (Max) (pA) | 0.02 |
Output current (Typ) (mA) | 22 |
Architecture | CMOS |
THD + N @ 1 kHz (Typ) (%) | 0.0007 |
- Unless Otherwise Noted, Typical Values at TA =
25°C, VS = 5 V. - Input Bias Current (VCM = 1 V)
- Maximum at 25°C ±20 fA
- Maximum at 85°C ±900 fA
- Offset Voltage ±26 μV
- Offset Voltage Drift – 1.5 μV/°C
- DC Open-Loop Gain 120 dB
- DC CMRR 100 dB
- Input Voltage Noise (at f = 1 kHz) 6.5 nV/√Hz
- THD 0.0007%
- Supply Current 1.3 mA
- GBW 17 MHz
- Slew Rate (Falling Edge) 12.76 V/μs
- Supply Voltage 1.8 V to 5.5 V
- Operating Temperature Range –40°C to 125°C
- 8-Pin SOIC
The LMP7721 is the industry?s lowest specified input bias current precision amplifier. The ultra-low input bias current is 3 fA, with a specified limit of ±20 fA at 25°C and ±900 fA at 85°C. This is achieved with the latest patent-pending technology of input bias current cancellation amplifier circuitry. This technology also maintains the ultra-low input bias current over the entire input common-mode voltage range of the amplifier.
Other outstanding features, such as low voltage noise (6.5 nV/√Hz), low DC-offset voltage (±150 μV maximum at 25°C) and low-offset voltage temperature coefficient (?1.5 μV/°C), improve system sensitivity and accuracy in high-precision applications. With a supply voltage range of 1.8 V to 5.5 V, the LMP7721 is the ideal choice for battery-operated, portable applications. The LMP7721 is part of the LMP precision amplifier family.
As part of Texas Instruments? PowerWise? products, the LMP7721 provides the remarkably wide-gain bandwidth product (GBW) of 17 MHz while consuming only 1.3 mA of current. This wide GBW along with the high open-loop gain of 120 dB enables accurate signal conditioning. With these specifications, the LMP7721 has the performance to excel in a wide variety of applications such as electrochemical cell amplifiers and sensor interface circuits.
The LMP7721 is offered in an 8-pin SOIC package with a special pinout that isolates the amplifier?s input from the power supply and output pins. With proper board layout techniques, the unique pinout of the LMP7721 will prevent PCB leakage current from reaching the input pins. Thus system error will be further reduced.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
