--- 产品详情 ---
Architecture | Fixed Gain/Buffer |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.8 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 11 |
GBW (Typ) (MHz) | 250 |
BW @ Acl (MHz) | 250 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 300 |
Vn at flatband (Typ) (nV/rtHz) | 9.3 |
Vn at 1 kHz (Typ) (nV/rtHz) | 9.2 |
Iq per channel (Typ) (mA) | 4.25 |
Vos (offset voltage @ 25 C) (Max) (mV) | 7.5 |
Rail-to-rail | In to V-, Out |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 72 |
Input bias current (Max) (pA) | 10000000 |
Offset drift (Typ) (uV/C) | 27 |
Output current (Typ) (mA) | 75 |
2nd harmonic (dBc) | 64 |
3rd harmonic (dBc) | 57 |
Frequency of harmonic distortion measurement (MHz) | 5 |
- HIGH BANDWIDTH: 75MHz (G = +2)
- LOW SUPPLY CURRENT: 7.8mA (VS = +5V)
- FLEXIBLE SUPPLY RANGE:
±1.5V to ±5.5V Dual Supply
+3V to +11V Single Supply - INPUT RANGE INCLUDES GROUND ON SINGLE SUPPLY
- 4.9VPP OUTPUT SWING ON +5V SUPPLY
- HIGH SLEW RATE: 350V/μs
- LOW INPUT VOLTAGE NOISE: 9.3nV/Hz
- APPLICATIONS
- SINGLE-SUPPLY VIDEO LINE DRIVERS
- CCD IMAGING CHANNELS
- LOW-POWER ULTRASOUND
- PORTABLE CONSUMER ELECTRONICS
All other trademarks are the property of their respective owners.
The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single +3V to +11V supply. Operation on ±1.5V to ±5.5V supplies is also supported. The input range extends below ground and to within 1.7V of the positive supply.
Using complementary common-emitter outputs provides an output swing to within 30mV of ground and 60mV of the positive supply. The high output drive current and low differential gain and phase errors also make it ideal for single-supply consumer video products.
Low distortion operation is ensured by high bandwidth product (75MHz) and slew rate (350V/μs), making the OPA2832 an ideal input buffer stage to 3V and 5V CMOS converters. Unlike earlier low-power, single-supply amplifiers, distortion performance improves as the signal swing is decreased. A low 9.3nV/Hz input voltage noise supports wide dynamic range operation.
The OPA2832 is available in an industry-standard SO-8 package or a small MSOP-8 package. For gains other than +1, ?1, or +2, consider the OPA2830.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
