--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.8 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 11 |
GBW (Typ) (MHz) | 110 |
BW @ Acl (MHz) | 250 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 550 |
Vn at flatband (Typ) (nV/rtHz) | 9.2 |
Vn at 1 kHz (Typ) (nV/rtHz) | 9.5 |
Iq per channel (Typ) (mA) | 4.25 |
Vos (offset voltage @ 25 C) (Max) (mV) | 7.5 |
Rail-to-rail | In to V-, Out |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 80 |
Input bias current (Max) (pA) | 10000000 |
Offset drift (Typ) (uV/C) | 27 |
Output current (Typ) (mA) | 75 |
2nd harmonic (dBc) | 66 |
3rd harmonic (dBc) | 77 |
Frequency of harmonic distortion measurement (MHz) | 5 |
- HIGH BANDWIDTH:
230MHz (G = +1), 100MHz (G = +2) - LOW SUPPLY CURRENT: 7.8mA (VS = +5V)
- FLEXIBLE SUPPLY RANGE:
±1.5V to ±5.5V Dual Supply
+3V to +11V Single Supply - INPUT RANGE INCLUDES GROUND ON SINGLE SUPPLY
- 4.82VPP OUTPUT SWING ON +5V SUPPLY
- HIGH SLEW RATE: 500V/μs
- LOW INPUT VOLTAGE NOISE: 9.2nV/
Hz
- AVAILABLE IN AN MSOP-8 PACKAGE
- APPLICATIONS
- SINGLE-SUPPLY ADC INPUT BUFFERS
- SINGLE-SUPPLY VIDEO LINE DRIVERS
- CCD IMAGING CHANNELS
- LOW-POWER ULTRASOUND
- PLL INTEGRATORS
- PORTABLE CONSUMER ELECTRONICS
- LOW-POWER ACTIVE FILTERS
All other trademarks are the property of their respective owners.
The OPA2830 is a dual, low-power, single-supply, wideband, voltage-feedback amplifier designed to operate on a single +3V or +5V supply. Operation on ±5V or +10V supplies is also supported. The input range extends below ground and to within 1.8V of the positive supply. Using complementary common-emitter outputs provides an output swing to within 25mV of ground and +VS while driving 150. High output drive current (75mA) and low differential gain and phase errors also make it ideal for single-supply consumer video products.
Low distortion operation is ensured by the high gain bandwidth product (100MHz) and slew rate (500V/μs), making the OPA2830 an ideal input buffer stage to 3V and 5V CMOS Analog-to-Digital Converters (ADCs). Unlike earlier low-power, single-supply amplifiers, distortion performance improves as the signal swing is decreased. A low 9.2nV/Hz input voltage noise supports wide dynamic range operation.
The OPA2830 is available in an industry-standard SO-8 package. The OPA2830 is also available in a small MSOP-8 package. For fixed-gain and line driver applications, consider the OPA2832.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
