--- 产品详情 ---
Number of channels (#) | 4 |
Architecture | DSL Line Driver |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 8 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 32 |
BW @ Acl (MHz) | 50 |
Acl, min spec gain (V/V) | 1 |
Vn at flatband (Typ) (nV/rtHz) | 3 |
Vn at 1 kHz (Typ) (nV/rtHz) | 3.1 |
Iq per channel (Typ) (mA) | 4.3 |
Vos (offset voltage @ 25 C) (Max) (mV) | 22 |
Rail-to-rail | No |
Features | Shutdown, Adjustable BW/IQ/IOUT |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 67 |
Input bias current (Max) (pA) | 10000000 |
Offset drift (Typ) (uV/C) | 7 |
GBW (Typ) (MHz) | 50 |
Output current (Typ) (mA) | 415 |
2nd harmonic (dBc) | 89 |
3rd harmonic (dBc) | 85 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- Trimmed Low-Power Consumption
- 4.2-mA/amp Full Bias Mode; 4.8 mA Max
- 3.2-mA/amp Mid Bias Mode; 3.7 mA Max
- 2.15-mA/amp Low Bias Mode; 2.5 mA Max
- Shutdown Mode and IADJ Pin for Variable Bias
- Low Noise
- 3-nV/√Hz Voltage Noise
- 5.9-pA/√Hz Inverting Current Noise
- 1.2-pA/√Hz Noninverting Current Noise
- Low MTPR Distortion
- -74 dB with ADSL and ADSL2
- -71 dB with ADSL2+ and -70 dB with ADSL2++
- -83 dBc THD (1 MHz, 100-Ω Differential)
- High Output Current: >415 mA (25-Ω Load)
- Wide Output Swing: 44 VPP (±12-V, 200-Ω Differential)
- Wide Bandwidth: 30 MHz (Gain = 5)
- Wide Power Supply Range: ±4 V to ±16 V
- APPLICATIONS
- Ideal For Power Sensitive, High Density ADSL, ADSL2, ADSL2+, and ADSL2++ Systems
PowerPAD is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners
The THS6184 is a dual-port, low-power current feedback differential line driver amplifier system ideal for xDSL systems. Its extremely low-power dissipation is ideal for ADSL, ADSL2, ADSL2+, and ADSL2++ systems that must achieve high densities in ADSL central office applications by combining two ports, or four amplifiers, into one package.
The unique architecture of the THS6184 allows the trimmed quiescent current to be much lower than existing line drivers while still achieving high linearity. Distortion at these low-power levels is good with -83-dBc THD at 1 MHz with the low bias mode of 4.2 mA/port. Fixed and variable multiple-bias settings of the amplifiers allows for enhanced power savings for line lengths where the full performance of the amplifier is not required.
The wide output swing of 44-VPP differentially with ±12-V power supplies coupled with over 415-mA current drive allow for wide dynamic range, keeping distortion minimized. With a low 3-nV/√ Hz voltage noise coupled with a low 5.9-pA/√Hz inverting current noise, the THS6184 increases the sensitivity of the receive signals allowing for better margins and reach.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
