--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 4 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 5 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
GBW (Typ) (MHz) | 250 |
BW @ Acl (MHz) | 650 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 240 |
Vn at flatband (Typ) (nV/rtHz) | 2.5 |
Vn at 1 kHz (Typ) (nV/rtHz) | 2.5 |
Iq per channel (Typ) (mA) | 5.6 |
Vos (offset voltage @ 25 C) (Max) (mV) | 0.8 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 85 |
Input bias current (Max) (pA) | 20000000 |
Offset drift (Typ) (uV/C) | 4 |
Output current (Typ) (mA) | 85 |
2nd harmonic (dBc) | 84 |
3rd harmonic (dBc) | 92 |
Frequency of harmonic distortion measurement (MHz) | 1 |
- HIGH BANDWIDTH: 220MHz (G = +2)
- HIGH OUTPUT CURRENT: ±85mA
- LOW INPUT NOISE: 2.5nV/Hz
- LOW SUPPLY CURRENT: 5.7mA/ch
- FLEXIBLE SUPPLY VOLTAGE:
±2V to ±6.3V Dual Supply
+4V to +12.6V Single Supply - EXCELLENT DC ACCURACY:
- Maximum 25°C Input Offset Voltage = 0.8mV
- Maximum 25°C Input Offset Current = 500nA
- APPLICATIONS
- LOW–COST VIDEO LINE DRIVERS
- ADC PREAMPS
- ACTIVE FILTERS
- LOW–NOISE INTEGRATORS
- PORTABLE TEST EQUIPMENT
- OPTICAL CHANNEL AMPLIFIERS
- LOW–POWER, BASEBAND AMPLIFIERS
- CCD IMAGING CHANNEL AMPLIFIERS
- OPA4650 UPGRADE
All trademarks are the property of their respective owners.
The OPA4820 provides a wideband, unity-gain stable, voltage-feedback amplifier with a very low input noise voltage and high output current using a low 5.7mA/ch supply current. At unity-gain, the OPA4820 gives > 600MHz bandwidth with < 1 dB peaking. The OPA4820 complements this high-speed operation with excellent DC precision in a low-power device. A worst-case input offset voltage of ±0.8mV and an offset current of ±500nA give excellent absolute DC precision for pulse amplifier applications.
Minimal input and output voltage swing headroom allow the OPA4820 to operate on a single +5V supply with > 2VPP output swing. While not a rail-to-rail (RR) output, this swing will support most emerging analog-to-digital converter (ADC) input ranges with lower power and noise than typical RR output op amps.
Exceptionally low dG/dP (0.01%/0.03°) supports low-cost composite video line driver applications. Existing designs can use the industry-standard quad pinout SO-14 package while emerging high-density portable applications can use the TSSOP-14.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
