--- 产品详情 ---
Architecture | Current FB |
Number of channels (#) | 2 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 7 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 12.6 |
GBW (Typ) (MHz) | 1500 |
BW @ Acl (MHz) | 1500 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 1700 |
Vn at flatband (Typ) (nV/rtHz) | 2.1 |
Vn at 1 kHz (Typ) (nV/rtHz) | 2.1 |
Iq per channel (Typ) (mA) | 5.8 |
Vos (offset voltage @ 25 C) (Max) (mV) | 3.2 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 60 |
Input bias current (Max) (pA) | 22000000 |
Offset drift (Typ) (uV/C) | 15 |
Output current (Typ) (mA) | 70 |
2nd harmonic (dBc) | 85 |
3rd harmonic (dBc) | 72 |
Frequency of harmonic distortion measurement (MHz) | 5 |
- UNITY GAIN STABLE BANDWIDTH: 1500MHz
- HIGH GAIN OF 2V/V BANDWIDTH: 690MHz
- LOW SUPPLY CURRENT: 5.8mA/ch
- HIGH SLEW RATE: 1700V/μs
- HIGH FULL-POWER BANDWIDTH: 670MHz
- LOW DIFFERENTIAL GAIN/PHASE:
???0.03%/0.015° - APPLICATIONS
- MEDICAL IMAGING
- WIDEBAND VIDEO LINE DRIVER
- DIFFERENTIAL RECEIVER
- ADC DRIVER
- HIGH-SPEED SIGNAL PROCESSING
- PULSE AMPLIFIER
- IMPROVED REPLACEMENT FOR OPA2658
All trademarks are the property of their respective owners.
The OPA2694 is a dual, ultra-wideband, low-power, current feedback operational amplifier featuring high slew rate and low differential gain/phase errors. An improved output stage provides ±70mA output drive with < 1.5V output voltage headroom. Low supply current with > 500MHz bandwidth meets the requirements of high density video routers. Being a current feedback design, the OPA2694 holds its bandwidth to very high gains?at a gain of 10, the OPA2694 will still provide > 200MHz bandwidth.
RF applications can use the OPA2694 as a low-power SAW pre-amplifier. Extremely high 3rd-order intercept is provided through 70MHz at much lower quiescent power than many typical RF amplifiers.
The OPA2694 is available in an industry-standard pinout in an SO-8 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
