--- 产品详情 ---
Architecture | Voltage FB |
Number of channels (#) | 1 |
Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.7 |
Total supply voltage (Max) (+5V=5, +/-5V=10) | 5 |
GBW (Typ) (MHz) | 3000 |
BW @ Acl (MHz) | 3000 |
Acl, min spec gain (V/V) | 1 |
Slew rate (Typ) (V/us) | 790 |
Vn at flatband (Typ) (nV/rtHz) | 2.4 |
Vn at 1 kHz (Typ) (nV/rtHz) | 6.4 |
Iq per channel (Typ) (mA) | 18 |
Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
Rail-to-rail | No |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
CMRR (Typ) (dB) | 95 |
Input bias current (Max) (pA) | 12000000 |
Offset drift (Typ) (uV/C) | 5 |
Output current (Typ) (mA) | 100 |
2nd harmonic (dBc) | 84 |
3rd harmonic (dBc) | 100 |
Frequency of harmonic distortion measurement (MHz) | 10 |
- Wide Bandwidth: 3 GHz
- High Slew Rate: 830 V/μs
- Low Voltage Noise: 2.8 nV/
Hz
- Single Supply: 5 V, 3 V
- Quiescent Current: 18 mA
- APPLICATIONS
- Active Filter
- ADC Driver
- Ultrasound
- Gamma Camera
- RF/Telecom
The THS4304 is a wideband, voltage-feedback operational amplifier designed for use in high-speed analog signal-processing chains operating with a single 5-V power supply. Developed in the BiCom3 silicon germanium process technology, the THS4304 offers best-in-class performance using a single 5-V supply as opposed to previous generations of operational amplifiers requiring ±5-V supplies.
The THS4304 is a traditional voltage-feedback topology that provides the following benefits: balanced inputs, low offset voltage and offset current, low offset drift, high common mode and power supply rejection ratio.
The THS4304 is offered in 8-pin MSOP package (DGK), the 8-pin SOIC package (D), and the space-saving 5-pin SOT-23 package (DBV).
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
